Results 1 to 13 of 13
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Need help - spring compressors
    Ok so alot of you read my thread a couple weeks ago that I got most of my 02 sport suspension on except for the rear springs. Well I just called the audi mechanic that I know, and told him the situation and he said the same thing that everyone else on here said: "They got the front springs on without compressors but they couldnt get the rears?"
    Well I asked a place to get a compressor because nobody around me rents them, so he told me Sears. So I'm about to run over to sears, but I remember when the mechanics at my dads repair shop told me about the compressors they said there was an adaptor or something for them to fit the springs it was some OEM part number like 1762/2 or something. But the audi mechanic I just talked to said just compressors would do. I just dont wanna go buy them and not be able to use them if I need another part to them.
    The more I explain the situation to people and the more they all say that thing about getting the fronts on and not the back, then the more i'm getting a feeling my dads mechanics just blew me off on the back springs because they didnt wanna waste the time because they thought they were doing it for me for free. Even though I still paid them $200 and I would never not pay them, they owe my dad favors sometimes. So I think im gonna go get the compressor and bring it back to them, if they cant use it i'll return it, and i'll have to let the audi mechanic take my car for the weekend and do it on the side.
    Thanks.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Need help - spring compressors
    You don't need spring compressors, just have them drop your subframe. It's a whole 2 bolts on either side after disconnecting the shock, lower arm, upper arm, sway bar, etc. Takes very little time. You have to get an alignment done anyway... Cheap spring compressors don't work well for our app. If you want a good one, this is it... expensive though...
    http://www.zdmak.com/wbstore/main.as...-1941MB&CTMP=1
    Aug 25 2007
    B6 S4
    ^yea, I just dont wanna go back and start arguing with them after they told me "they couldnt do it". Plus if those compressors are too cheap then that link is a good one, but too expensive. So I think ill just call the audi mechanic and let him take the car this weekend on the side, cuz i cant do the work myself.
    -Nick
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    i just put an 02 sport suspension on my car on friday by myself. i went to advance auto and they loaned me their spring compressors. and yes, they were the cheaper kind, and they worked like a charm. I had to compress the rear with the subframe dropped simply because i didnt have a pry bar that worked. i also compressed the front to make it easier to get the struts in/out.
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Aug 25 2007
    B6 S4
    Ok, well I made the appointment for the audi mechanic i know to do it on the side, so he'll have my car for the weekend and finally these things can be done with.
    -Nick
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Oh man.. I'm sure it will all work out in the end.. look forward to the finished product.
    Veteran Member Four Rings 02SILVANT's Avatar
    Aug 24 2007
    2005 Audi S4 Avant 6MT
    Vancouver, WA
    Get some GOOD pictures up once your done i wanna see how it looks all done!
    2002 Silver A4 Avant Auto - SOLD
    2005 Black S4 Avant 6MT - SOLD
    2005 Mercedes E500 Sport - SOLD
    2005 BMW 330ci ZHP Convert imola red with hard top - SOLD
    Currently 2015 Audi Q7 3.0T S-Line V12 TDI Body Kit
    SPARK, Mental Focused Energy Drink:https://www.advocare.com/08082595/St...lavor=L&size=P
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I cant belive this is still going on.
    Its just funny how they got the front on and not the rears..
    -Sami-
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    you can 'rent' spring compressors from auto zone (actually free, but you have to leave a deposit) and do the job yourself. the back is stupid easy. even a beginner could manage this in an afternoon. write up on a4mods i believe.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Dec 25 2004
    Earth
    A picture is worth....
    Ask Mike@PureMS http://forums.audiworld.com/a4gen2/msgs/979229.phtml
    The correct spring compressor, prevents loosening of subframe bolts!
    Got'm from here- http://www.toolss.com/wbstore/main.a...CTMP=1&LowCt=0
    Senior Member Three Rings ad03avant's Avatar
    Jun 21 2008
    2003 A4 Avant Quattro
    Olympia, WA
    I did mine by dropping the subframe and used the OEM (autozone) compressors. Pryed them out with a prybar at the end. It worked just fine and I had never changed a set of springs in my life.
    D
    Andy
    -2003 A4 Avant Quattro
    -APR Stage 2 +, Achtuning Snub, Avic D3, USP Front, S4 blades and bi-xenons, APR stealth, 034 HFC, ASA JH3 18', platinum VMR sport gauge, h-sport sways, ABT springs, Koni sports, Zimmerman sport rotors, Stoptech stage 1
    Dec 08 2007
    Easton,PA
    i thought the back was easier than the front,they are just screwing around with u because they dont feel like doin the back, i bought autozone compressors for 50 bucks and they worked perfectly.
    2002 A4 1.8t 5 speed maunal-revo stage 2
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    It was the hardest springs I have ever done but I did a set on my buddy's a4 and used spring compressor for front which was easy but we did the back with no compressor because the ones I have don't fit. Didn't loosen sub frame. Just elbow grease and pry bar. It was a mother trucker though.
