Results 1 to 9 of 9
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    problem after another now my wheels shake
    Well my wheels used to shake when i had my other set of rims on with wheel spacers. I thought it was wheel balance was off took it to the shop balanced it and they sed my wheels was bent. I bit the bullet and bought a set of brand new rims this time i didnt need the wheel spacers. Driving to work today my wheels start shaking at 50 mph and it only shakes at 50 55 mph any ideas whats going on here. Thanks in advance.
    Active Member Four Rings
    Oct 12 2006
    2000 Nogaro S4
    Hillsboro OR
    Re: problem after another now my wheels shake
    tires? i had a flat spot on one of mine...and that caused shaking...
    2002 A4 - sold
    1990 CQ - sold (sadly)
    2000 S4 - sold (sadly-er)
    currently audiless
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Tie rods? did you check them? Also Control arms. HOw do they look?
    Mar 11 2008
    san diego ca
    Im gonna check them after work today. Are those the symptoms of those going bad?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by xx_s4quattro_xx View Post
    Yeah, failing TRE's and CA's can give you a shimmy at certain speeds. Did you increase the diameter with the new wheels? Also worth checking is the torque on the wheel bolts and also that they are the right type for the wheel.
    Mar 11 2008
    san diego ca
    Yea im thinking tires too. Because when i put my stocks on they dont shake. My fenders are cutting the hell out of my tires i think thats whey its shaking cutting my threads off i need to switch back to 225 right now i have 235.
    Mar 11 2008
    san diego ca
    The wheels i have are 18x8 bolt pattern 5x112 32mm offset. Tires are 235/40/r18
    Jan 29 2007
    08 S4 00 S4
    MD
    Right, but what bolts are you using with them? Most aftermarket wheels take a cone seat bolt, but anyway, just double check the torque. Also, your 17's don't shake so you could have suspension issues that are more noticable with the larger wheels. Tires, may be an issue but I don't think they've gotten out of balance from a little rubbing, if they were balnced right in the first place.
    Mar 11 2008
    san diego ca
    Alright ill check them. Is it safe if i run 225 in the front and 235 in the back? Or is it going to mess up my differential? Thanks
