Results 1 to 15 of 15
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Another AWE Exhaust question --- hangs too damn low
    I've seen some AWE setups in here where the tips look like they're set at "normal" stock height. How'd you guys achieve taht?
    My setup hangs way too low .. positioning looks like an afterthought. I'd like to raise it somehow - would zip ties work? Suggestions? Thanks.
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    Re: Another AWE Exhaust question --- hangs too damn low
    maybe exhaust hangers? get some shorter ones!
    just an idea =)
    Senior Member Two Rings pcdrj's Avatar
    Jan 23 2007
    '06 A4 2.0 Quattro TIP
    Philadelphia
    Did you install it yourself or have a shop do it?
    Veteran Member Four Rings Six Speed Turbo's Avatar
    Feb 09 2007
    Hopes, Dreams, Tools, Car Parts
    Killeen, TX
    Quote Originally Posted by DuviVr6 View Post
    just an idea =)
    WHAT????? That's crazy talk, you bite your tongue Sir.
    2016 S3 Prestige - Glacier White Metallic, APR Stage 3+, APR TCU upgrade, APR CAI, APR FMIC, APR Catchcan, APR Lowering Springs, P3 Guage
    YouTube Channel https://www.youtube.com/channel/UC88...LbgXXvRHPvW3Xw <---SUBSCRIBE
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    You can try a small metal clamp around the stainless steel post of the exhaust so it doesn't slide out of the hanger. That should help it stay level.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I agree with the shorter clamps (the U shaped ones) but I don't think a zip tie would be too good of an idea.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    haha i think zip ties would melt...
    Feb 12 2004
    PA-NJ
    Pics would be helpful.
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    dont buy a b7 and fix it with zipties... Any exhaust shop should be able to fix this, a few pics of the current setup would be helpful.
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Jul 01 2007
    Ask, USA
    Sure, I'll get them up for you guys.. one side hangs lower than the other..
    yeah, im a total noob when it comes to exhaust
    2015 Audi Q3
    2009 BMW 328i
    2007 Audi A4
    DUH! an Audi
    los angeles, CA
    pics, no zip ties and go back to show to adjust the hangers...it shouldnt go lower than how oem has them.
    When i saw an exhaust install, the hangers have a screw you should be able to adjust it a tad more up.
    Established Member Two Rings tre's Avatar
    Jul 07 2008
    B8 S4, B8 2.0 prestige, modded B7
    Chicago
    Did your stock system have level tips? There is not really much adjustment in the AWE system - because of this it has to be made precisely (unlike Milltek which is held together with clamps so you have to rotate the mid and rear sections to get a good fit - I was always re-adjusting my Milltek). There is one adjustment screw that connects to two rear sections which is really more for side to side adjustment. I suppose if the install was not that great it may make one side lower then the other. If you remove the screw between the two rear pipe sections, you may want to have a couple people to hold each tip horizontally and vertically level so you can tighten that screw back up. Less likely, you may have a bent exhaust hanger on the AWE rear section (the hanger is on the muffler). The metal hanger on the muffler slides into the rubber hanger on the car. Adjustment screw is pointed to in the picture below where it says "Mandrel bent tubing"
    08' B7 A4 2.0T 6 speed quattro
    - Stasis reflash, Ohlins SL suspension, Stasis exhaust, Stoptech 355 BBK, RS4 rear sway, light OZ wheels
    2011 B8 2.0T Stock
    2011 B8 S4 Stock
    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by muffinman View Post
    I spoke to our technician and he suggested looking at the shims installed on your exhaust hangers. Check to see if you have enough clearance to remove some of the shims without making the exhaust hit anything. This should allow you to get the exhaust to sit how you want it to.
    Let me know how it works for you!
    Jul 01 2007
    Ask, USA
    Quote Originally Posted by Alex/A.W.E. View Post
    Printed this thread to show the muffler shop - thanks Alex and everyone else for the advice. AZ FTW
    2015 Audi Q3
    2009 BMW 328i
    2007 Audi A4
    Nov 16 2006
    Skokie, IL
    you shoud post pictures though to show us how low it is sitting and maybe AWE can respond again if they see anything wrong.
