Results 1 to 4 of 4
    Veteran Member Three Rings fritzner's Avatar
    Nov 30 2006
    05 Red USP Avant 1.8T 6spd
    Pittsburgh, PA
    will C6 wheel fit on a C5??.. will 245/40/18 work on a C5..
    will C6 wheels fit on a C5??.. are the offsets and hub diameter similar??..
    will 245/40/18 work on a C5 (with stock suspension)??..
    >'05 Brilliant Red A4 USP Avant 1.8T 6spd
    ...REVO-II | TT injectors | RS4 sway | RS4 Pedals | podi
    ...Moven SP-10 (sportec reps) | 3.0L brakes | RNS-E | coolbox
    ...USP CLUB MEMBER #118
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: will C6 wheel fit on a C5??.. will 245/40/18 work on a C5..
    Tire size is a little too small in diameter, may mess up the speedo/abs/etc. We don't have a cross reference for OE wheels, but none of our aftermarket wheels fit both generations due to problems with offsets.
    Nov 30 2006
    Pittsburgh, PA
    thanks doc..
    that sucks..
    Nov 30 2006
    Pittsburgh, PA
    from this link, it appears the C6 rims are 8" et48 and my C5 rims are 7.5" et 43, so 5 - 10mm spacers would be required.. the hubs are the same..
    http://www.myturbodiesel.com/1000q_h...s_overview.htm
    http://www.rims-n-tires.com/rt_specs.jsp
