Results 1 to 3 of 3
    Veteran Member Three Rings Fink_tha_Audi's Avatar
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Middletown, Delaware
    Need Help For a Proper Tuning
    I got 99.5 A4. Engine blew, bought a new Jasper engine and installed ATP's GTRS Eliminator Kit with MIKA fueling kit. Got the car back from shop and ran pretty good for a whilw until the check engine came and said "High Fuel Pressure" basically running rich. I took it back to the shop (by the way this shop that I took my car really dont know what they are doing in the performance sector of Audi's) they wanted to put back in the old ecu and injectors (ecu has APR programming). This made the car run great especially with bigger turbo. Max psi before BT was about16-17psi and now with BT 17-20psi. My question what is the best programming for a GT2871R, that is reliable. I read a couple of threads about MIKA, saying that it sucks. My car is DD.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Need Help For a Proper Tuning
    You have a couple options. You have Chris Tapp/Eurodyne and there is Unitronic to name 2. Chris Tapp also offers a Meth file if you wanna do that too, idk about Uni. do a search you'll see a lot of threads about this. And yeah stay away from MIKA
    Jun 14 2008
    99.5 Audi A4 1.8t Q
    Quote Originally Posted by njm23 View Post
    Should I have a MBC on it now since I am running a little high then what APR tuned for?
