Results 1 to 40 of 65
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Schrick cams, come help.
    Anyone know info on them? I cant find a place that lists them for the 20v only 16v and less. I wanted to see the different stages.
    A guy has a pair that he bought but doesnt know the number of them. He said when he ordered them that he told the people he wanted something a little more aggresive than stock and said they are a touch more aggresive than the small Cat cams which im assuming are the 3651s. So what would these be?
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Schrick cams, come help.
    Bob@QED has told me if you go with any more aggressive than cat 3651 lift and duration then you need to lose the VVT. Not like you care about that though right?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Do you have the part number? I have the Schrick catalog at home. Schrick doe quite a bit of custom grinds for tuners in Germany and Sweden.
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by CO AVANT View Post
    What is vvt no I dont care. I am about to buy an AEB head and was thinking about the cams as well.
    And Greg I asked him in an email if he could find out the numbers for me so I will get back to you on that.
    ~David~
    CTS-V 9.6@148
    Dec 25 2004
    Earth
    Last set of Schricks I bought, came from a tuner in Canada...
    Here's Schricks 2008 Catalog:
    http://www.avl-schrick.com/dat/MK/AV...ICK_2008_E.pdf
    Company website:
    US operations:
    Schrick Inc
    529 Simmon Drive
    Osceola WI 54020
    (715)294-1806
    Apr 24 2005
    E55 AMG, CTS-V
    he believes these are the specs of them:
    246° Intake Camshaft mated to 252° Exhaust Camshaft. 124° - Overlap Intake. 107° - Overlap Exhaust. 11mm Lift (Intake / Exhaust).
    ~David~
    CTS-V 9.6@148
    Dec 25 2004
    Earth
    Scrick lists 4 cams in their catalog for the B6:
    0301 E1 601-V0 Lift- 9,2 Duration-260/126
    0301 A1 681-00 Lift-10,80 Duration 268/114
    0246 E1 601-01 Lift-10,9 Duration-260/ /112
    0246 A1 601-01 Lift-10,9 Duration-260/112
    Apr 24 2005
    E55 AMG, CTS-V
    0467-E1-461-00/0467-A1-521-00 is the part number he had listed with all that other info. when he said he thinks that is what they were. I asked him to look for a part number on them and get back to me.
    Remember these were for an AEB head so the part number would probably not be the same as a B6. The head is off a 98 Passat.
    ~David~
    CTS-V 9.6@148
    Dec 25 2004
    Earth
    Quote Originally Posted by A4 TSCHUSS View Post
    0467-E1-461-00/0467-A1-521-00 is the part number he had listed with all that other info. when he said he thinks that is what they were. I asked him to look for a part number on them and get back to me.Remember these were for an AEB head so the part number would probably not be the same as a B6. The head is off a 98 Passat.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Those are for a TFSI according to the catalog, if it is a good deal, jump on them. Will not fit your motor but David will buy them in a second from you.
    Apr 24 2005
    E55 AMG, CTS-V
    Crap I hope he is wrong with that number. Gotta wait for him to look at the cams for a part number. And Greg they arent new cams.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    ok got the numbers off the cams.
    Intake: 301 521 00 E1 I found these #s-------> 252/110
    Exhaust: 301 601 A1 -----------------------> 260/114
    What do you all think?
    ~David~
    CTS-V 9.6@148
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Legit, grab em
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    What can you get them for?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 24 2005
    E55 AMG, CTS-V
    $275
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    what are those comparable to? I havent ever researched cams because I never planned on getting them. Is that aggresive or mild or middle?
    ~David~
    CTS-V 9.6@148
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Pretty sure thats the exact set of Schricks I have been running since 2002 and Lucas has been running for even longer.
    Apr 24 2005
    E55 AMG, CTS-V
    damn so those are probably pretty aggresive then ha? I dont want nothing to crazy giving me bad idle or whatnot or only for power way up top
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    IIRC, they're about the same specs of the cams I have. Not a bad idle at all. And about 4k it's like uping the boost by 7-8psi and pull to 8500 without sweat.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    that is what I want to hear
    ~David~
    CTS-V 9.6@148
    Jul 07 2004
    socal
    252/260 is a mid cam setup, its not anywhere near being a wild cam set. If you look at the EVo guys, they jump right to 272/272 cams and thats even with their stock turbos. For my next setup it might have to be something in the 272/280 range seeing that I plan on running a much larger T4 flanged turbo soon.
    Apr 24 2005
    E55 AMG, CTS-V
    sounds good
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    my stock cam gear should be fine right?
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    stock gear is fine as long as cam is not retarded or advanced :)
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Apr 24 2005
    E55 AMG, CTS-V
    as in like it wasnt put on the right tooth with the chain connecting the two and needing to use an adjustable gear to correct the error?
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    I can't remember what the 3658's spec out at. I'm looking at them on QED, but I don't know which cam is int. and which is exh. I think it uses the 3651 intake and 3653 exh. and I can't find my cam card.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    yeah I tried finding them on catcams site but they didnt list the 3658
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    The 3658 is a 3651 int and 3653 exh.
    I'm back bitches!
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Just make sure you aren't buying them from AudiRcR on here. I bought a set from him months ago and he shipped me a set of stock cams.
    Apr 24 2005
    E55 AMG, CTS-V
    3651 says 245/262
    3653 says 239/245
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by Condo View Post
    no it is a guy from vortex
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    3651 says 245/262
    3653 says 239/245
    But which one is intake and which is exh?
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    haha, I dont know! It doesnt say.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Straight from my Cat Cams 3651 card that was in the box:
    Intake: 245deg duration
    Exhaust: 262deg duration
    You can get away with the stock cam gear but its advised to run an adjustable so you can tweak it. Due to the nature of how my head & block were decked I needed the adjustable cam gear with the 3651s. I was off 1/2 a tooth on the timing belt otherwise. Now that I've got it all set up I'm going to readjust the gear to add some more advance in and get better performance.
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    so then Chris's 3658 setup should be 245/245? That can't be right.
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I would think so, yes.
    What are the stock cam specs?
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    but arent the 3658 set more aggresive than the 3651?
    And the higher the number is more aggresive correct which would mean Chris's are lower significantly since the duration is quite a bit lower.
    245/262 of you compared to 245/245 of him. And mine are 252/260
    ~David~
    CTS-V 9.6@148
    Jun 30 2007
    Raleigh, NC
    on what mike was saying about the evos and such --- i remember my buddy's evo.. that thing was on 272's w/JUST an exhaust and a AMS pro-tune... made 275awhp
    is there really any good reason we can't run an aggressive set like that? like, is there something different that would keep us from doing it?
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Idle
    Cold starts for me right now are a bitch. The car doesn't want to idle, even with the 3651s. I'm chalking it up to the cold sparkplugs (for boost) and my tune at this point in time.
    -Doug
    Jun 30 2007
    Raleigh, NC
    hmmm i ran cold plugs for awhile and have 630's, and never had cold start issues -- makes me wanna throw a set of cams in so we can see if its your tune or the cams (or a combo) giving you issues.
    another question - my understanding of the purpose of cams is to allow more fuel/air into/out of the engine by lengthening/shortening the times the valves are open/closed. (though im not sure about that, its not something ive looked into much, and which I'm still learning about)
    but given that that info is correct -- wouldn't we need tunes for our specific cams to see any real gains from them? I'm more on the side of chip tuning (for now) but even I can see a problem with a generic tune for a cammed setup...
    The Awesome™
