Results 1 to 6 of 6
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    Idle drop after coming to a stop
    So after driving a few miles and coming to a red light, my RPMs drop from 1000 to 900 and then come back up.
    Possible vacuum leak?
    GO KNIGHTS!
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Re: Idle drop after coming to a stop
    my 04 1.8tq idles at 800 when at a complete stop. only time it idles higher is when i first turn it on, it idles at 1200 for 1-2 minutes, then after the engine warms up it drops down to 800.
    sounds like you might have a vacuum leak.
    Established Member Two Rings Altec-Racing's Avatar
    Aug 31 2007
    04 USP blk/blk
    I have the same problem man. I also get a temperary drop any time the front end of the car gets loaded up, ie heavy braking, or going of a speed bump.... i can't figure it out :(
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Try cleaning the throttle body and doing a TB adaptation.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    used to happen to me and it was a faulty maf.... but mine would drop real low and almost stall.... at first it started with like 100 rpm's then to almost staling.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Feb 21 2008
    Orlando, FL
    Had the throttle body cleaned a while back so I don't think that's it. When the RPMs drop there is a not normal vibration from the engine.
    GO KNIGHTS!
