Results 1 to 16 of 16
Thread: Suspension
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    Exclamation Suspension
    Ok guys i need some help with a small problem that has just arrised in my B5 S4!!
    For the past week that i have been hearing a strange noise coming from the front of the car...after taking it to my guru mechanic..lolol..he informed me that my shocks were gone!!!
    Since i wanted to dump the car next year its fine..the only problem is that i wanted to do it next year and right now my budget is limited since i just purchased the car about a month ago also bought a awe boost gauge,forge diverter valves,cross drilled rotors,etc!!!
    I was told that i could get some coilovers from vmaxx or tein for about 700 CANADIAN dollars!!
    The question is...are they any good????
    My brother has a 97 rx7 with tein coilovers and he loves them and another buddy of mine has the vmaxx on his 2007 gli and he has no complaints!!!
    In order for me to buy them i need to know if u guys(s4 owners) approve of them!!!
    Thanx for the help!!!!
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Re: Exhaust!!!
    Wait. What does this have to do with exhaust? Lol.
    I've heard mixed reviews on VMAXXs, some people love them, others argue that they use the stock spring rates and make for a shitty ride.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Apr 05 2007
    Re: Suspension
    i suggest making this part of your daily breakfast:
    Apr 05 2007
    Re: Suspension
    Quote Originally Posted by Boosted-S4 View Post
    if you want to 'dump' the car in a year why would you spend money on coilovers? do it if you like wiping your ass with hundreds, otherwise just get some bilstein struts and call it a day.
    Senior Member Two Rings Aphex350's Avatar
    Feb 11 2008
    Peekskill, NY
    Re: Suspension
    What ever happened to spelling?
    2000 Santorin S4
    AWE Stage 3+
    Aug 03 2008
    Silver S4
    Re: Suspension
    the only reason why i wanted coilovers is because its snows like crazy here in toronto and i plan to drive it in the winter so with coilovers i could raise the car and in the summer lower it !!!
    sorry about the spelling guys!!!Some people are 2 perfect to read posts with some spelling errors!!!!
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Suspension
    I had to read every post and think to figure out chocks was shocks. Proof reading is your friend.
    I have no personal experience, but I have heard nothing but good about Tein products.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Re: Suspension
    Im still trying to figure out where the chocks are located.....
    Does the C5 have chocks, or I get.. Its one of S4 things!
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Apr 05 2007
    Re: Suspension
    oh sorry i misunderstood you.. when you said 'dump the car next year' i thought you meant sell it, not lower it.
    don't spend $700 on Vmaxx when for a couple hundred more you could get Koni or Stasis SS
    Aug 06 2008
    Canadia
    Re: Suspension
    raising and lowering your car is going to drastically change your cars alignment and as a result affect freeway driving characteristics (making it less safe) and tire wear.
    I would leave it stock unless you want to spend $100 on an alignment twice a year or just get a winter beater.
    Veteran Member Three Rings AudiHolicS4's Avatar
    Apr 16 2008
    Pasadena, MD
    Re: Suspension
    i made the mistake of buying vmaxxs cause i knew someone with a A4 that said they liked them but with an S4 u might want to just save a couple more hundred and get something good i just got vogtlands and i love them the vmaxxs bottomed out in the back all the time i guess i was riding low but still my vogtlands dont do that and there low too
    2000 Silver S4
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: Suspension
    Quote Originally Posted by MacDaddy View Post
    my car is lowered pretty good on neuspeed springs and stock shocks, and I have experienced nothing but good with them. If you get a good alignment after doing the springs, your camber shouldn't change taht dramatically to affect your highway driving. I've only had to get 2 alignments, both from mechanics at Audi error. One of them drove too quickly over a speed bump and bent a control arm somehow, and one just didnt align it after doing suspension work. As long as you get it aligned every time you change your height, you should be fine.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Aug 06 2008
    Canadia
    Re: Suspension
    do you have a print out of your alignment specs from before and after the alignment was done?
    Senior Member Two Rings one4eyes's Avatar
    Jul 31 2007
    Bay Area, Cali
    Re: Suspension
    I have Tein basic....I like them...I have it at the highest setting right now...and still lower...with Tein...you either get lower setting or slam...but if you are talking about raising it up for winter....you won't get the stock height...and I don't thing the Tein basic will hold up at the track if you plan to track sometimes...
    * OEM Performance *
    Aug 03 2008
    Silver S4
    Re: Suspension
    the problem is that i live in canada where it snows alot and i was told that once the coilovers get some salt on them that i wont be able to adjust them cause they will seize!!!
    Should i go stock shocks and lowering springs???
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Suspension
    just take care of your car and wash it.. and they wont sieze..
    maybe before you put them on put some anti sieze on the threads as well..
    but like i said.. take care of your car and wash the underbody ever so often in the winter and you shouldnt have a problem.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
