Results 1 to 14 of 14
    Oct 30 2006
    B8 A4 Avant 6spd
    Got a list of codes
    Audi A4 2.8
    Saturday,12,July,2008,13:36:45:55227
    VCDS Release 805.0: Generic OBD2
    Mode 03: Emission related fault codes
    Address 10 (Engine): 16 Faults Found:
    P1425 - EVAP Purge Valve (N80): Short to Ground
    P1472 - EVAP Leak Detection Pump: Short to Ground
    P1435 - Secondary Air Pump Relay (J299): Short to Ground
    P1530 - Camshaft Timing Adjustment: Short to Ground
    P1421 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
    P1121 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
    P1117 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
    P0102 - Mass Air Flow Sensor (G70): Signal too Low
    P1115 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
    P1119 - Oxygen (Lambda) Sensor Heating Circuit: B2 S1: Short to Ground
    P0134 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0154 - Oxygen (Lambda) Sensor B2 S1: No Activity
    P1114 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1140 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
    P0140 - Oxygen (Lambda) Sensor B1 S2: No Activity
    P0160 - Oxygen (Lambda) Sensor B2 S2: No Activity
    I'm pretty sure its a bad ground somewhere or blown fuse / relay, any ideas other than mine?
    -18 718 GTS
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Got a list of codes
    ECM Fuse?
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Why'd you scan in generic OBD2 mode? Maybe some VAG-specific codes you can't see that will help figure out what is wrong if you check DTCs stored in the engine control module.
    "You know you have a bad idea when Ford guys are making fun of you."
    Jan 21 2006
    6MT BT Avant Ti
    RI
    "theskuh" just had the same codes come up and it was a fuse.
    Aug 19 2008
    Boston
    Quote Originally Posted by chris164935 View Post
    I am the one who scanned it, Not sure how to use the Vag com system entirely. Just fuddled with it and got it to a point where I could get it to scan.
    nebone22- do you happen to know which fuse it was?
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    It was the 4 one up in the middle row on the bottom of the fuse panel. I can't remember the number.
    Apr 18 2007
    Orange Park, FL
    Quote Originally Posted by theskuh View Post
    What caused it to pop?
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Actually it didn't pop, When I checked there wasn't a fuse there. For the life of me I can't think I ever moved it or took it out. I am hardly ever in the fuse panel. But I must of or the fuse fairy got it.
    It is #34 I checked my car
    Sixfiveoh had his pop and throw the codes.
    Aug 19 2008
    Boston
    all the same codes?
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Mine where somewhat different but pretty close
    17833 P1425 Evap purge valve short to ground
    17525- P1117 O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
    17843 P1435
    Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
    17829 P1421
    Sec.Air Inj.Valve Circ Short to Ground
    17697 P1289
    Turbocharger bypass valve short to ground
    17880 P1472
    EVAP Emission Contr.LDP Circ Short to Ground
    16486- P0102
    Mass or Volume Air Flow Circ Low Input
    17523- P1115
    O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
    16518- P0134
    O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected - intermittent
    17522- P1114
    Bank1-Sensor2 Internal Resistant too High
    Aug 19 2008
    Boston
    cool thanks, we'll check these out, and hopefully get this stupid CEL off... how was the car running for all of you? Our avant runs fine
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    If you open up Vag-Com you can hit "select" (big button upper left) to pick the control module you want to scan or hit "Auto-Scan"(big button top row, middle) and scan ALL the modules.
    I haven't ever used Vag-Com to scan the generic OBD2 stuff, I'd imagine it works like anything else. The absolute basics and that's it.
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by nebone22 View Post
    told ya!
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Yea you did mention that.
    We need a VAG Jeopardy.
