Results 1 to 9 of 9
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    04 S4 spacer question
    Which size spacer would i need to bring the factory wheels out so they are flush with the wheel well?
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Senior Member Two Rings khyber's Avatar
    Nov 21 2007
    B6 S4
    Socal
    Re: 04 S4 spacer question
    A lot of people go with 10mm spacers. I personally like it a little lower but I think depending on the wheel it will rub. I had a wheel that was a 38 offset and with 10mm spacers I had no rubbing, but my current wheels with a 35 offset and 10mm spacers do rub. But I think the general consensus is that an offset of 35 is perfect, and I think the stock Avus' are a 45 offset.
    Veteran Member Three Rings Speedymon's Avatar
    Aug 27 2005
    2004 S4
    San Antonio, Tx
    I have 10mm all around and like the look. Absolutely flush you looking at 12 or 15 in the back.
    Imola_Jon's supervisor...
    Aug 14 2008
    09 CTS-V
    Ontario
    Quote Originally Posted by Speedymon View Post
    Pic please
    JHMotorsports
    AUDI Revolution
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    I think 15mm puts the stock wheel out to the fender perfectly. I'm was dropped on PSS9's, 25.5" Front and 25.75" Rear, Michelin PS2's. 15mm H&R spacers rear only. It NEVER rubbed...not once...even with 5 people in the car. I'd add 8-10mm up front if I were running my stockers.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    i just purchased 8mm for front and 15mm for rear. ill get pics up when i put them on next week...
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
    Aug 14 2008
    09 CTS-V
    Ontario
    Quote Originally Posted by XwalkerX View Post
    Thanks for the pics S4J! I wont be lowering the car since it will be a winter car too and its just a hassle for me to raise and lower with the seasons hehe.. But i just cant stand seeing my wheels tucked into the fenders.
    Awesome Waller, cant wait to see the pics! How much did you pay for the spacers?
    JHMotorsports
    AUDI Revolution
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    Quote Originally Posted by S4J View Post
    Any alignment or uneven tire wear issues with spacers?
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Sep 26 2006
    Nor Cal
    Quote Originally Posted by CHECKERED View Post
    None for me.
