Results 1 to 4 of 4
    Registered User Four Rings Dion@Achtuning's Avatar
    Jul 01 2008
    ACHTUN!NG | Wheel as low as $499 a set!!
    We've got another 1000+ wheels due in on the next container and we've gotta make room!! Get in on these deals before it's too late!
    B6 S4 - 114 Wheel: $879.00!!
    ▫ 5x112
    ▫ 18x8, 45mm offset
    B5 S4 - 114 Wheel: $639.00!!
    ▫ 5x100/112
    ▫ 17x7.5, 42mm offset
    S8 - 114 Wheel: $799.00!!
    ▫ 5x112
    ▫ 18x8, 48mm offset
    RS6 - 172 Wheel: $876.00!!
    ▫ 5x100
    ▫ 19x8, 30mm offset
    RS6 - 172 Wheel: $939.00!!
    ▫ 5x112
    ▫ 19x8, 45mm offset
    RS6 - 172 Wheel: $879.00!!
    ▫ 5x112
    ▫ 18x8, 45mm offset
    A8 - 199 Wheel: $1279.00!!
    ▫ 5x112
    ▫ 20x9, 35mm offset
    Concept Nuvo Wheel: $939.00!!
    ▫ 5x100/112
    ▫ 19x8, 35mm offset
    B7 Sport 295 Wheel: $599.00!!
    ▫ 5x112
    ▫ 18x8, 35mm offset
    B7 Sport 295 Wheel: $919.00!!
    ▫ 5x112
    ▫ 19x8, 43mm offset
    New Turbo Wheel: $799.00!!
    ▫ 5x112
    ▫ 18x8, 35mm offset
    Laredo Wheel: $639.00!!
    ▫ 5x112
    ▫ 18x8.5, 20mm offset
    * 1 wheel has had a tire mounted and dismounted for a test fit but is in excellent condition.
    Q7-446 Wheel: $799.00!!
    ▫ 5x130
    ▫ 19x8.5, 62mm offset
    ▫ 5x130
    ▫ 20x9, 60mm offset
    VW-280 Wheel: $716.00!!
    ▫ 5x112
    ▫ 18×7.5, 45mm offset
    VW-212 Wheel: $799.00!!
    ▫ 5x112
    ▫ 18×8, 52mm offset
    Brio Wheel: $749.00 set of 5!!
    ▫ 5x112
    ▫ 18×7.5, 35mm offset
    Spark Wheel: $499.00!!
    ▫ 5x112
    ▫ 17×8, 35mm offset
    TSW Volcano Wheel: $449.00!!
    ▫ 5x112
    ▫ 19×8, 32mm offset
    Euromesh Wheel: $799.00!!
    ▫ 5x112
    ▫ 18×8.5, 35mm offset
    Post up or contact us if you have any fitment or general questions.
    Active Member Two Rings B-Rob's Avatar
    Mar 13 2008
    Bellevue, WA
    Re: ACHTUN!NG | Wheel as low as $499 a set!!
    What's the weight on the Concept Nuvo wheel? You don't happen to have any pics of it on a B6, do you? And will there be specials on tire packages to go along with the wheels?
    '03 A4 3.0 quattro, dolphin gray on ebony
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Make some Titanium package reps asap ;)
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Jul 01 2008
    ^ I hear you! We definitely like the wheel, just not sure if it's gonna happen in the very near future.
    Quote Originally Posted by B-Rob View Post
    The Nuvo is 32 lbs., definitely one of our heavier replica wheels. We can certainly set you up with some tires that we stock, or you can even have Tire Rack send us your tire order and we'll take care of the mounting/balancing. Just be sure you use the link to Tire Rack in the left margin of our Achtuning online catalog to get the mounting/balancing credit. As for pics, here is what I was able to come up with...
    Click here to check out the rest of the Nuvo gallery.
