Results 1 to 4 of 4
    Senior Member Two Rings dreVanHalen's Avatar
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    PLEASE help ASAP (wheel size)
    so this has probably been asked about a million times but i couldn't find anything through search. I am looking into getting new wheels for my b5 a4 quattro. Looking at a set of 18x8 rs4 reps that are et42 spacing. I am not sure exactly what this means so is this gonna mean the wheels are going to stick out more, or are they going to possibly rub. Just curious If I will need spacers or if it will fit stock and how it will look.
    Thanks in advance,
    Taylor
    Jun 14 2005
    Anaheim, CA
    Re: PLEASE help ASAP (wheel size)
    Here at VMR Wheels we offer the the best looking Rs4 reps on the market! With the most concave face with the closest design to the real Rs4 wheel. Offered in 18x8.5 +38 and 19x8.5 +38 with Hyper Silver, Gunmetal, & Onyx Black. These fitments fit perfectly flush with your vehicle without any spacers or hub centric rings. You can also use your OEM lug bolts still! All of our wheels are JWL VIA tested for strength and safety. If you have any questions, feel free to contact me at my email charles@velocitymotoring.com
    Thanks,
    -Charles@VMRWheels
    www.vmrwheels.com
    Hyper Silver
    Gunmetal
    Onyx Black
    Brandon @ VMR Wheels
    Brandon@Velocitymotoring.com | 714.442.7916 Ext 108 | www.velocitymotoring.com| Instagram | | | Blog
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Normally we do ET35 to ET40, so the wheels you are looking at may rub a little on the strut. A good test fit will tell you if you need a small spacer or not.
    Aug 19 2008
    B5 a4 1.8TQM
    San Marcos, CA
    my only problem is i would have to order the wheels. i can't do a test fit if i dont have them here ha. worst case scenario i need to order spacers which will run me about 100 right?
