Results 1 to 14 of 14
    Aug 18 2008
    Illionis
    Couple quick questions from a noob
    Hello All
    Did a bit of searching but couldn't find my answers and I figure it would be a good time to introduce myself!
    I just purchased a 2002 A4 1.8T Quattro for my wife on Saturday. It only has 16K miles on it, and appears brand new. Due to the hairpins and hard candy's in the center console (not kidding!), and the slight combination of Aqua-net and new car smell (still not kidding!) in the air, I can only assume that an older lady drove it and took remarkable care of it. Runs great and after about 5 hours of going over it and 3 test drives, couldn't find any faults with it.
    However, no drivers manual, I have one on order but have a few questions.
    1. Anything I need to keep an eye on? I have read about transmission issues with some of the 02's, but wanted to gain a bit more understanding.
    2. We have two buttons near the switch to pop the truck at the back of the map holder on the drivers side door, what the hell are they for?
    3. And since it's my wife's car and I mistakenly showed her a pic with the wood trim (walnut?), she would like that instead of the AU trim, any place I can order it? ( would prefer actual trim instead of the 3M stuff)
    Senior Member Two Rings 97ss10's Avatar
    Jul 24 2008
    2003 A4 Quattro 3.0 / 2005 Nissan Frontier NISMO
    Louisiana
    Re: Couple quick questions from a noob
    Welcome to AZ! I'm sort of a NOOB also but I think I can help you with your questions.
    1. I have a 3.0 so I'm not up on the problems with the 1.8 other than I've read a little
    about oil sludge issues in the motor? Maybe someone else will help with that one.
    2. The 2 buttons on the door panel are for the sensors for the alarm. Incase you leave a dog or something in the car you can turn off the motion sensor. The other is for a tilt sensor so if you must have it towed you can turn that sensor off.
    3. As for the trim, you can order it from the dealership or there's another AZ sponsor site that sells it. I get all my parts from Kyle at [email protected] . Most of his prices are below dealer prices and are factory sealed parts.
    Hope this helped and again...welcome!
    2003 A4 3.0L Quattro
    1998 Camaro SS 6spd
    2005 Frontier CC Nismo
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    To answer the question about the tranny, if it's a CVT auto then yes i have heard of problems with them. With that low of miles i dont see how it would give you any just yet. Yes, ONLY use synthetic oil because there is a major problem with sludge. other than that i think the other guy answered everything else. Congrats on the buy and goodluck, they are fun!
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Here's a good thread to peruse for some fun stuff...Click
    Oil sludge buildup is a known issue in the 1.8, but since your car is such low mileage, just keep changing the oil with synthetic and the Audi oversized filters and you'll be ok.
    The 1.8 is generally trouble free with a few exceptions. Coil packs could fail, but are a cheap fix.
    Later on down the road (around 75K), you'll have to replace the timing belt.
    Little things start to nickel and dime you (vacuum leaks, hoses, etc.) but thats any car.
    Keep up w/ the regular maintenance and all should be good
    Nice find, BTW.
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    If you're looking for wood trim you could probably find someone willing to trade by posting in the wanted section.
    Established Member Two Rings Teratorn's Avatar
    May 30 2008
    Ashburn, VA
    I think this is on the list in the link Demea provided, but there's a shelf under the steering wheel. You may want to check if the driver's manual is there.
    One of the first things I had to replace when I got my '03 was the oil dipstick and neck/sleeve. It becomes very brittle with heat. But with only 16K, it shouldn't be a problem for quite a while for you.
    Jun 10 2008
    sf
    Yea, first time I pulled on my dipstick, it broke the handle. I assumed that when I took it in for maintenance the dealer would just toss a new one in there. WRONG.
    Aug 18 2008
    Illionis
    Thanks all for the helpful answers!
    Quote Originally Posted by Teratorn View Post
    My wife showed up this morning with a manual, someone she works with has a 02 A4 and loaned it to us. One of the first things I saw was in it was where the manual was stored and was able to located it, along with the radio code. I must have missed it when I read the Easter Eggs thread. I also found the original bill of sale addressed to a "Mildred and Howard", so I was half right about a little old lady.
    Thanks for the tips on the oil, I have to do full synthetic with my TDI basically because of the Turbo, so I suspected the same for this one. And I will make sure that the Wife doesn't yank on the dip stick too hard.
    2002 Audi A4 1.8T Quattro
    2004 VW Jetta 1.9 TDI
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by xlr8ed View Post
    What, there can't be any hot young girls named Mildred? On the same topic, I found the original bill of sale in my car too (or something with the original owner's name on it) and he had the exact same name, first middle and last, as one of my good friends. Really weird actually.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Aug 18 2008
    Illionis
    Quote Originally Posted by Exanimas View Post
    I believe there can be hot women named Mildred, just not after 1956
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Coil packs were mentioned, but to give you a little more info on them if you dont know, here goes:
    They are what plugs into the spark plug (4 on the top of the head) If the car ever were to start idleing terrible and misfiring like it is running on 3 cylinders instead of 4 and the engine light is flashing then most likely you have had a coil pack fail on you. They are around $30 a piece (little cheaper at a VW dealer) and it is good idea to keep one in the trunk just in case.
    If the problem were to ever come up you can simply leave the engine running and unplug the power plug from the coil. Do one of them at a time and see if the engine loses power or not. When you unplug one that doesnt affect the idle (engine doesnt want to stall or drop down a few 100 rpm) then you found the culpret and simply take that spare you have in the trunk and pop it in and you are good to go.
    Also mentioned earlier the car originally came with a smaller oil filter which you most likely still have. Get that changed out which allows for another roughly 1/2 quart of oil in the car. Car takes right at 5 quarts with the larger filters which everyone will sell now (all auto parts stores) since audi made the update due to the sludge problems.
    I see you found the easter eggs thread so you are set there for learning about all the tricks.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by 97ss10 View Post
    OEMPl.us
    Also maybe hit up Chase at A&P, as they may be able to locate a used set.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Congrats on a low milage find... pretty much everything was covered above, enjoy and welcome.
    Mar 09 2008
    is full of crap.
    Boston, MA
    Touché sir, congrats on the new car.
    -Nick
