- Since I am only going to a t28 do I even need to do rods?
- Are all aftermarket rods for these engines the same length?
- with the ABA crank and stock bore I will net 132cc but with 83.5mm bore I will net 252cc. What is the benefit vs cost on these i.e. would I see much gain from staying stock bore/ would it be that much more gain to go 83.5mm?
- As for pistons, will any aftermarket ones work or do they have to be special to clear the valves?
- Would the power benefit be worth it with a "small" turbo
Im tired from reading lol so I probably forgot some questions. If you have any input/comments/suggestions/info feel free. TIA guys
