Results 1 to 4 of 4
    Veteran Member Three Rings audiman27's Avatar
    May 30 2008
    Port Saint Lucie, FL
    Fuel Gage goes to full, even with car off?
    Hey everyone, My fuel gage is screwy. It reads pegged full most of the time, and when I shut off the car it will stay there. Sometimes it goes to half with the car off. The DTE digital remaining works great. I unplugged the sender and the gage didin't move. I did remove the plug behind the gage and put it back in, It went to zero and then back where it needed to be. It worked fine for a couple of days, then back to the screwy stuff. I'm thinking I have a bad instrument cluster. Any way the Vag-com could re-adapt it?
    May 30 2008
    Re: Fuel Gage goes to full, even with car off?
    bump!
    May 30 2008
    anybody?
    Veteran Member Three Rings dfresh000's Avatar
    NNJ
    faulty fuel sensor. i had the same symptoms as you and after it was replaced my gauge was back to normal. i believe many others on here have had the same problem.. good luck
    '13 Monsoon Gray S4 P+ | DSG | Carbon Atlas | B&O | Sports Diff | More Fun to Come
    '14 Monsoon Gray Q5 3.0T P+ | B&O
