Results 1 to 11 of 11
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    got my car back from the shop.
    Well after 3 days of my car sitting in the shop getting the ssac turbo back installed i got it back today. But everything is not all good now my coolant light is blinking but im not leaking coolant or anything. Do you guys have any suggestion? Can it be my coolant temp sensor? LMk thanks in advance.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: got my car back from the shop.
    i had the same thing after a timing belt job, all that happened was the coolant was mixed a little rich, my mechanic told me this might happen and to just top it off with a little distilled water.
    Although, a coolant issue with down pipe install, shouldnt not happen as the two are unrelated.
    B5 S4 AWE Stage 3 - sold
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    check the wiring on the bottom of the coolant tank. mine was very brittle and broke. so it was telling me my coolant was too low.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Mar 11 2008
    san diego ca
    alright thanks guys so should i replace the sensor if my cooloant is still full?
    Sep 19 2006
    The Man Cave
    isnt the sensor in the coolant tank? check the wiring. they prob moved the tank to get to the 02's and downpipe heat shields.
    //NEVER FOLLOW
    Mar 11 2008
    san diego ca
    alright i really apreciate your guys help. Im really thankful for this forum i went back to the shop i know they had to do it. Because b4 my car went in there it was fine when it came out. It came out with a blinking cooloant light a cracked driver side engine cover and one zip tie on my coolant tank instead of a screw. So is it cool if i roll with the blinking light for now because i dont see no leaks or nothing my coolant level is still at max and if i would to fix it how should i do so? LMk thanks im gonna check the sensor tomorrow after work when the car cools down.
    Apr 05 2007
    i bet the sensor is just not plugged in. just lift up the coolant tank (after removing 2 screws and one zip tie..heh) and see if it's plugged in. $10 says it isn't
    Aug 06 2008
    Canadia
    Quote Originally Posted by exorcet View Post
    +1
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    are you really willing to BET that 10 bucks?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Senior Member Two Rings SpoolPastYou's Avatar
    Jul 15 2008
    Miami
    Quote Originally Posted by xx_s4quattro_xx View Post
    LOL who the F* did you entrust your car too?!? it was just an exhaust install and all that went wrong!?
    Mar 11 2008
    san diego ca
    exorcet you were right i open up the hood today b4 going to work looked under there and there it was unplgged ha ha thank you guys.
