Results 1 to 13 of 13
    Senior Member Two Rings gsverz's Avatar
    Oct 05 2007
    North Jersey
    i think my timing belt broke
    car stalls yesterday while driving... pulled some codes today :
    16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    P0012 - 35-00 - -
    16726 - Camshaft Pos.Sensor Circ Low Input
    P0342 - 35-00 - -
    16486 - Mass or Volume Air Flow Circ Low Input
    P0102 - 35-00 - -
    the belt is not physically torn and it still has decent tension, but from searching i gather there is no need deny it...
    my car currently has 101K on it, do you guys think that the new lawsuit claim we all received will cover the repairs since it is technically still under 105K? should i try to contact AoA directly or a dealer? any advice is greatly appreciated...
    can anyone think of ANYTHING else that this can be?
    and yes, it should have been changed a while ago, i f*cked up
    thanks guys
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: i think my timing belt broke
    its not usually the belt that breaks but the tensioner that breaks. check that bad boy out.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Oct 05 2007
    North Jersey
    would the belt have slack then? and do i have to take the front end off to do so?
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Pull the covers and see if you can check the tensioner. You might have to put it in the service position though.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Remove the top plastic cover and visually inspect if the belt is loose
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Stampy View Post
    I prefer the "semi-service" position. take the bumper skin off and the bolts out from the "core support", don't remove it, just slide it forward so you can put two bolts in by the fenders. That clears up at least 4" of extra room. Since you don't need to remove the toothed crank pulley, there's no need to get an impact or anything that big in there.
    It's possible that it jumped time. A tooth off on the belt will let it still run, but it'll make very little power.
    IIRC the tensioner is part of the class action suit. Are you in the model years covered? 2000-2003? You may be covered, but if it still runs you probably didn't do any serious damage.
    Oct 05 2007
    North Jersey
    the car's not running and it doesn't start... and yes i think i'm covered by the class action settlement... i just hope audi doesn't try to blame the failure on something else...
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    When you try start the car does it ''crank'' really fast? Or faster than it would normally sound?
    Oct 05 2007
    North Jersey
    it doesn't sound as if the engine is turning... i'm not sure if the crank is turning or not but the camshaft is def not... it sounds faster and more high pitched...
    Sep 14 2006
    Lansing, MI
    did you try to open the top plastic cover and visually inspect the timing belt to see if its loose?
    it takes on ly two clips and a pull of the cover
    SOLD
    Oct 05 2007
    North Jersey
    yeah, it's not completely loose, but i don't know how tight it should be... but it looks like it should be tighter than it is... I would need to take off the front end or put it in the service position to see if the tensioner went but I don't really want to go through that, i'd rather just have Audi inspect it since it's a free check anyway...
    Apr 18 2008
    08 A4 2.0TQMS, 87 16v Scirocco, 01 NB TDI, 01 4Runner, 00 BMW K1200RS
    Palm Coast, FL
    I had a belt go bad on a 1.8t Passat. the teeth on the belt literally fell off but the belt stayed tensioned and the crank would spin but the head wouldn't. If you can turn the key to start it and it sounds like things are spinning but the belt doesn't move the camshaft pully, then you've probably got the same type of belt failure I had.
    Sep 14 2006
    Lansing, MI
    does it crank on and stays on or it just cranks and stays off.
    SOLD
