Originally Posted by
demea
I think it would be good
The further away from the turbo's heat, the cooler the IAT.
it doesn't matter if you have a K03. trust me.
what do you think will happen when that air gets into the turbo (already super hot) and then gets compressed? (compression = heat)
you can worry about pre-turbo intake temps when you're grasping at straws for every fraction of a HP that you can make on your BAT, until then it's not worth it.
now that is NOT to say that it isn't a good idea - I'm turning a spare headlight into an intake myself.. I've done lots of reading on the subject and I want to give a few things a try to see if there are any real benefits (won't get into that here) I'm just saying that if you're really concerned you should just get or make a heat shield and keep your stock box.
