Results 1 to 9 of 9
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    GTRS turbo and HFC?
    I have done a light search and really did not fid what I was looking for. I want to get a bigger turbo and was contemplating the k04 since i could use a HFC. Can i use a HFC with the GTRS for emmissions purposes? I have a test pipe now and the wife is complaining about the sound. whats the best price for this setup? I plan on staying with revo and possibly doing the install myself. I'm also debating on whether im going with a FMIC or keeping stock and just goiing water/meth. Funds are little low right now so im working ona smaller budget.
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: GTRS turbo and HFC?
    For what its worth, I'm running a fully built 2.0L stroker with a HFC. I had the HFC on my 1.8T with a full GT28RS and it worked fine.
    Being you live in NJ (and right where I grew up), I highly recommend a FMIC with a larger turbo like the GTRS.
    I can do the install and/or help you install everything if you like. My September and October are fairly open as of now.
    -Doug
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Doug, is it possible to run the gtrs on a OE cat? and what HFC are you running? Milltek
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I would think the OE cat would cause too much backpressure since is not a "high-flow"
    I have a 200cell cat that was custom welded into my downpipe by ASP (part of their GT28RS kit).
    -Doug
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    So I guess I'll have to install a resonator then, if I use a test pipe or HFC. I hope my exhaust won't be too loud. Thanks.
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    It is a federal offense to run a test pipe, it is also a federal offense to run a HFC. Same fine either way, might as well run the test pipe.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Quote Originally Posted by 400HPA4 View Post
    Never heard of someone getting busted for a test pipe/ HFC. Here in Quebec or anywhere in Canada land for that matter. No emission or inspection required, but anyways I like how you think!
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Feb 02 2008
    Somerset, NJ
    Thanks for the response. More than likely I should be able to do a FMIC if I get the GTRS but was consodering the w/m if the budget really got tight.
    As for the test pipe, im just not feelin the smell that im getting while driving/ or idling. Atleast with a HFC I can cut down on the odor a little and hopefully pass emmissions.
    Who do you guys recommend getting the GTRS kit from?
    RIP 2003 A4 1.8TQM
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Eurocode Tuning in CA
    -Doug
