Results 1 to 6 of 6
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    C5 A6 Multifunction steering wheel options?
    Would like to know if anyone has successfully swapped out their C5 A6 four spoke (fugly) MFSW for something a bit more sporty (B6 , B7, TT flat bottom) and if so, what changes did you need (cancelling ring, control module, air bag, etc) to make it work?
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    Re: C5 A6 Multifunction steering wheel options?
    im in the process of doing this right now. i have a b5 s4 wheel sitting in my basement with the airbag and everything. not sure whats required for the newer wheels, but i believe most of the older 3 point wheels are direct swap
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by 02 A6 2.7T View Post
    I would if I could keep all my buttons and have the nicer wheel.....
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Mar 22 2005
    Kitchener, Ontario
    i got an aftermarket headunit. my buttons no worky
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Established Member Two Rings THM's Avatar
    Jun 06 2007
    Audi A6 4.2
    Chicago
    if you are talking about something like this steering wheel http://cgi.ebay.com/ebaymotors/Audi-...spagenameZWDVW
    its plug and play you dont need any other parts just steering wheel and airbag
    but if you want rs6 with paddles you will need new self canceling ring,
    2000 a6 4.2
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by THM View Post
    I was thinking more like this one http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245 .
    This is similar to the sport wheel from the B7 A4. I'm just not sure if the spline is the same as the A6 and whether the the multifunction buttons will work the RNS-E nav functions without changing the control module.
