Finally got around to putting in my 034 mounts this weekend.. i did street density motor mounts and track tranny mount.. i did the motor mounts first... not terribly hard but the passenger side isnt the easiest to reach and you dont want your car slightly cooled down (unless you like the smell of your own burning flesh) for some reason i could not get the snub to line up to save my effing life!
i finally put on two washers where the snub bracket bolts to the engine to make it fit but it was touching on the drivers side of the snub cup.. the washers moved it just off it....
so i would probably get all track mounts if i did it again.. no real increased vibrrations... but less motor movement for sure...
now the track tranny mount is another story. the install took a little longer and it was tricky to get the mount out from the cross member but not bad...
when i first started the car.. i felt a lot more connected to it
a lot more vibrations.. once i got it settled it, they have been reduced quite a bit..... i can still feel a little more through the wheel/shifter but its not annoying or anything.. you feel it most when you first start the car.....
shifter feel is greatly improved with the tranny mount.. all in all a good investment!
on a side note, i also threw in some AutoRX with some good ole dino castrol GTX... im going to take it easy for 2500 miles and let it do its thing... but i dont know if i should/will switch back to full syn for the second rinse phase of autorx or leave dino oil in for that as well? i might email autorx and get their advice
