Results 1 to 17 of 17
Thread: tannie problems
    Account Terminated Two Rings wreckedimolas4's Avatar
    Jun 11 2008
    silver b5 stg 2+ 95 m3
    almont
    tannie problems
    i just put a new first to second shift coolar in and did not rplace synchros they looked fine, but my car grinds third if i shift at high revs,and just now if i down shift into second at high revs it grinds aswell. I put a new clutch slave and i have a vast stage three hybrid clutch, butthink my pressure plate might be bad. i need some possible answers in what i should replace?????
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Re: tannie problems
    sounds like a syncro. that was happening to me in 2nd gear. i had the syncros, shift collar, and 2nd gear itself replaced. i also drove it around like that for 6 months.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Re: tannie problems
    Who's Tannie? :)
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Jun 11 2008
    almont
    Re: tannie problems
    I have the vast hybrid ceramic clutch and rs4 pp with lite weight flywheel. And a new clutch slave so what could it be leading to this problem... this is pissing me off i just put a new shift collar in it. I knew I should of put the synchros in. What shit luck I have
    Dec 03 2007
    Potomac, MD
    Re: tannie problems
    engrish?
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: tannie problems
    lol
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Jun 11 2008
    almont
    Re: tannie problems
    besides proof reading my question's, could you just answer them?
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: tannie problems
    I'm not trying to be an ass, what was the question? (note the question mark at the end of my question). . .I'm being an ass now.
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Re: tannie problems
    your typie sucky.
    SBSC
    I also like to live dangerously.
    Dec 06 2007
    Calgary, AB, Canada
    Re: tannie problems
    Quote Originally Posted by wreckedimolas4 View Post
    DEFINITELY should have replaced the synchros while the tranny was apart. Sounds like you'll need to rip it apart again and replace them. What kind and how much tranny oil did you put in?
    Jun 11 2008
    almont
    Re: tannie problems
    3 1/2 quarts of redline
    Dec 06 2007
    Calgary, AB, Canada
    Re: tannie problems
    That's a problem. It should have 2.4 quarts of Redline MT90. Pull the fill plug on the driver's side of the tranny by the output flange, and use an allen key to dip into the hole. The fluid level should be 7mm +/1 1mm below the bottom edge of the hole.
    Sep 19 2006
    The Man Cave
    Re: tannie problems
    yeah that is a lot of fluid.
    //NEVER FOLLOW
    Jun 11 2008
    almont
    Re: tannie problems
    ohhh sorry i ment 2 and a half my bad.. i forgot how much i put in but it was 2 1/2
    Dec 06 2007
    Calgary, AB, Canada
    Re: tannie problems
    Ok, well that's not so bad then. I think you're going to have to replace the synchros if it's really bothering you.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Re: tannie problems
    well spooling.....more people would be inclined to help you if you wern't such a low-life liar who started 2 forum wars, and completely fabricated the biggest lies known to man...
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    Re: tannie problems
    Spooling. . is that you? Seriously? In that case, just hit up your uber rich parents for a stasis tranny rebuild and problem solved. And you'll have one the fastest S4's known to man.
