Results 1 to 11 of 11
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    BT sputtering at 10 psi
    I have a a full gt2871r kit. I have unitronics tune, mafless. The car has been running great, boosting up to 20 psi. Ok now the problem, everytime it hits 10psi the car just stutters and the check engine light flashes, meaning it's misfiring. The only codes it's throwing is " too lean" and "cylinder2 misfire". I have changed the sparkplugs, I have checked almost all hoses and Intercooler piping. So I have no idea what else to look at. If you guys could help me out I would greatly appreciate it.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: BT sputtering at 10 psi
    coilpacks
    Jul 03 2008
    A4
    change the coil pack, the offten go
    Jan 25 2006
    A4 2.0T
    MD
    You can also switch that coil pack and see if the misfire moves to the new cylinder for confirmation.
    Oct 30 2007
    Griffin, GA
    I switched the coilpacks from cylinder #2 to cylinder #3 and I erased the codes, and went for a test drive, and sure enough the misfiring cylinder went to #3 so new coilpacks are on the way. Is it ok that my coilpacks part# is 06B-905-115L and the ones I am ordering are 06B-905-115R?
    And why would the misfire only happen when it hits 10psi?
    ** 2001 A4 TQM
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Those coil packs are just weird. They decide at random when to misfire.
    I had a customer's B6 in the shop that had a misfire. I moved the coilpack from #2 to #4 and somehow the car picked up that #3 and #4 started misfiring after that.
    I installed one OEM coil and the car quit misfiring. $27 well spent.
    Yes, the part number is fine. A lot of Audi's part numbers get updated over the years.
    The first thing they'll change is the letter following the Bosch #.
    Feb 27 2005
    North Wales, PA
    you are only boosting 10psi if you are in limp mode and still using the factory n75 valve to control boost.
    Oct 30 2007
    Griffin, GA
    I'm using a greddy profec b spec II to control boost.
    ** 2001 A4 TQM
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Quote Originally Posted by f15046 View Post
    i would also change your plugs while your at it, what do you have your boost settings at for 20psi
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Oct 30 2007
    Griffin, GA
    I changed the plugs 800 miles ago. I'm sure it's the coilpacks. And what do you mean, why do I have boost set at 20 psi??
    ** 2001 A4 TQM
    May 31 2005
    Dallas
    no I was saying what do you have your boost settings at to get 20 psi with your greddy boost electronic boost controller, I have the same controller and was trying to compare our settings
