Results 1 to 8 of 8
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    Different amp with Bose system
    Has anyone ever run their Bose system with just a stronger amp or know if this would be a good idea? I tried searching but couldnt quite find what i was looking for. I'm not a bass junkie or anything but i hardly get any from my speakers. I dont know if the subs are nonfunctional or if its how the Bose system is supposed to sound but after i vag'd the system it didnt show me any problems. Any comments are appreciated.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: Different amp with Bose system
    you just need to find the amp and tap the the right signals. These wires coming from the amp will hook up to a line out converter and then run to an aftermarket amp then amp to sub.
    But i think what you are asking is getting rid of the Bose AMP and hooking up a new one. If i did this i would consider replacing all the speakers. I'm sure you could find something on crutchfield.
    B5 S4 AWE Stage 3 - sold
    Nov 20 2007
    Murfreesboro, TN
    I am pretty sure it can't be done because bose speakers are usually 1 ohm and that would fry most aftermarket amps out there. If you get another amp, replace the speakers too.
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Quote Originally Posted by MikeS View Post
    EXACTLY
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Quote Originally Posted by a4rings View Post
    EXACTLY
    not if you get a quality amp. there are many out there that will run 1 ohm, however its not worth getting one for the stock subs.
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Jun 02 2007
    thanks for the input guys
    -Douglas McArthur
    Semper Fi!!!
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    You don't get any bass? I'd check the sub first. I get boatloads from mine, all completely stock.
    Stg 2 B5 S4
    Nov 23 2007
    Columbus, OH
    you get so much bass that the glue works it self loose. snap, crackle and pop
