Results 1 to 8 of 8
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    AEB-AMB Head swap
    Is the AEB head just a direct swap for the AMB?
    Looking to buy USP Front.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: AEB-AMB Head swap
    yes
    - Clint
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    yes
    okay thats what i figured. Someone whom i wont name tried to tell me otherwise. Im slowly rebuilding it as well as my engine for a high revving 1.8
    Oct 29 2005
    10speed
    San Francisco, CA
    good thats a solid option, I should have mine done in the next few weeks. The only thing youre going to have to choose to do something with is the chain tensioner. The AMB motor has VVT but the AEB does not. You can just leave the non-VVT tensioner in the AEB but youll get a CEL
    - Clint
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You will get a MIL because of the absence of VVT. SAI will not work either. Both of the faults can be removed by a programmer such as APR/REVO or Unitronics
    Make sure the AEB head has all of the cam caps, many people will sell them knowing they are missing cam caps, they are virtually impossible to replace, and work properly. If you do replace them, you have to have the head line bored.
    Jun 24 2008
    E46 M3
    Woodinville WA
    While I can't say wether it can or can not be done, I've always been under the impression that it could not be done. Again, I don't know for sure but I have always "heard" and "been told" that it couldn't be done. Just throwing out info and things to consider.
    The AEB and ATW engine are based on the old 2.0L block with the water pump hanging off the side of the block. Also referred to as "External Water Pump". The only difference between the two is that AEB does not have Air injection and the ATW does have air injection. So the only difference is the head casting. No big deal as the exhaust/air passage can be blocked off in many different ways. Simplest being just mounting a "dummy" combi valve. Anywho, AEB and ATW use M11x1.5x96mm Head Bolts.
    The AMB and all other (except above mentioned) 1.8Ts all use the same block with the timing belt driven water pump, also referred to as "Internal Water Pump". Only a few of the newer style 1.8T's don't have Air injection but I don't recall which specific engine codes don't. Again, the air injection is a relatively minor detail. Though the hitch lies with the head bolts. The timing belt pump engines use M10x1.5x115mm head bolts.
    Both head bolts have 15mm diameter heads. The head gasket is also the same for both blocks.
    I'd also like to note that the AEB and ATW engines are so sought after not because of the heads but rather the bottom ends as the cranks and rods are more "heavy duty" so to say. You can also install a Cam adjuster in place of a plain tensioner on any of the engines without any problems.
    The crankcase vent plumbing and air injection plumbing can be dealt with easily enough. The AEB and ATW vent plumbing have seperate adaptors mounting to the block where as all other 1.8T's have the vent plumbing and oil condensation drain back through the oil filter stand/adaptor. Again, that stuff is not a big deal.
    I guess long story short, I think the reason I have always heard that the older style heads could not be used was because of the head bolts and people just being too lazy to trim 19 - 20 mm off the M10 bolts. BTW 11mm bolts are very uncommon not to mention in a 1.5 thread pitch. 10mm bolts generally use a 1.5 thread pitch but I doubt you'll find generic socket cap bolts as "torque to yield" bolts (stretch bolts)
    My two cents would be to figure out wether you need air injection or not. If so, I would just get my hands on a ATW engine and build that for high rev's and high HP rather than building a frankenmotor which still leaves you with the "weaker" bottom end. Like I said, swapping a chain tensioner for a cam adjuster is no big deal.
    Just my 2 cents. Who knows, maybe I'm just some idiot with no clue. If so, someone please correct me. For those who wana disagree purely for the sake of arguement, then by all means, fire away.
    C
    Jun 24 2008
    E46 M3
    Woodinville WA
    Ohh yeah....forgot.
    be carefull with OE and Aftermarket head bolts. Aftermarket bolts are fine and all but use a different tool.
    www.samstagsales.com sells the OE tool and a Hazet tool for the aftermarket.
    C
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    SAI can't be used but the VVT chain tensioner can be swapped it.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
