Results 1 to 6 of 6
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Undercar shield replacement
    So after I jack up the car today to do some work I find that the plastic dirt shield that protects the underside of the engine is gone. The only thing I can figure is that I lost it when we had some of the bad rains a few weeks ago and I came home late at night after work. I'm going to look at some of the local junkyards to see if they have a wrecked S4 to see if I can pull one. If not, where is another place I could get one or does the same year A4 fit?
    Feb 17 2008
    Ottawa Ont.
    Re: Undercar shield replacement
    w8 passat unit. half the pice.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I'd leave it off. Mine was gone when I bought my S4 3 years ago and havnt had any problems with it off.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    the belly pan you mean???
    Jan 11 2007
    Salt Lake City, Utah
    2nd the Passat W8 belly pan, much cheaper. If you want sturdy and don't care about the weight you can get the bulletproof panzer bellypan, that's what I did. Or you can just leave it off, mine's been off for months now (still have to put the panzer on).
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Jun 23 2008
    NC
    Thanks for the info. It's been fine so far and who knows when I actually lost it. There is some other work I need to get done before that.
