Results 1 to 40 of 40
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    My sweet dyno - have some ?'s
    First off here is the dyno sheet.By the way this is the first run all others were for less power.
    What should i be looking for that's killing over 100hp to the wheels.The car hit 22psi and tapered to 21 psi during this run.
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    Re: My sweet dyno - have some ?'s
    Quote Originally Posted by AudiTechS4 View Post
    a new tune ;)
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    +1
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    so your both saying there is nothing else to cause the loss?other then detonation what else pulls timing that could kill the power
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    im not dreaming of over 400hp to the wheels i have 178 to the wheels.another s4 with apr 93 program and rs4/rs6 hybrids and 25psi produced about 350 hp to the wheels.same dyno same night. actually right after i dyno'd.
    and even with 100hp to the wheels im still not over even 300.
    i have 315 crank tq are you telling me that seems realistic with a stage3 car?
    Mar 14 2007
    michigan
    I was looking at the graph i didnt read the numbers below sorry, ya i would say theres a problem or the dyno is #ucked up
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    did your timing skip? bad EGT?
    Veteran Member Three Rings hoosierchemist's Avatar
    Apr 12 2008
    2000 Nogaro S4
    Indiana
    does the ambient temperature being over 100F have anything to do with it??
    Mar 14 2007
    michigan
    Hows your ait lower then the ambient air?
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    well i have no faults for timing but i can check on Monday at work if timing is correct. Will an egt pull timing ? for somereason i thought it pulled boost also . I have no mbc also so its under n75 control
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i dont know where they got the iat # they didnt have anything hooked up to my car
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i know the high temp doesnt help but the car right after me ran and was producing 350hp to the wheels.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    also that night a4 2.0l put down 190hp to the wheels with and exhaust test pipe and a tune
    Mar 14 2007
    michigan
    maybe its the CUSTOM tune, how does the car feel because those are worse then a bone stock s4?
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    it feels faster than my chipped s4 stg 2, haven't done any runs against anyone else though.
    i work for audi and it feels faster that a stock b6 s4
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i wish i could log so i could throw those up. oh and btw im on stock intercoolers so that might have really killed the numbers and the pulls were on 91 octane.the car that put 350 down was on a 93 program and had a mix of 94 and had er sidemounts in so that could be a big reason why he pulled more just wondering what i should look for as far as my car maybe going into a limp mode.Sorry for the confusion.
    Apr 05 2007
    you absolutely need to log - something is wrong with your car or the dyno for your session.
    On the same tune (well, 91 octane version) I'm running a ~3.8 fats on 91 octane in 80 degree weather on shitty RS4 intercoolers (calculates to ~450chp / 475tq).
    I would guess you have a massive boost leak, bad EGT or o2 sensors, or the like. Something is seriously killing your power. Marc's new tunes are excellent.. the original 'custom' tune people like to give so much flack about is old news.. I must say the new, updated tunes he has for both 91 and 93 octane are great. But, even if perchance you have the 'old' tune it still shouldn't be NEARLY that bad..
    Apr 05 2007
    Quote Originally Posted by generationjdm View Post
    he has much better, updated files now -- not the 'highly speculated XXX rip' people like to scream about. that's old news and an 'old tune' at this point..
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i'm definitely not doubting the tune.Every one who has it likes it that i have talked too.i know its probably something with my car.probably an egt form what im gathering. yeah i just installed it 3 weeks ago.
    Apr 05 2007
    also - looking at the graphs again. AMBIENT is over 100 degrees. on stock intercoolers, 91 octane and 22 psi spike on a dyno with unkown 'fan quality' well.. it's not a great cocktail. Motronic management will jump in and pull timing like a mother-****** (and dump fuel like a mofo)!
    Again.. logs - IAT data, etc would be hugely helpful. i have a feeling the heat just made motronic say 'yeah right'. I wonder what your IAT's actually were with 22psi, stock intercoolers, 101 ambient and 91 octane. i would venture to guess close to 200 maybe?
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    yeah i know the heat is killing power i just didnt know that it was going to kill that much.
    I'll log next saturday on a drive to payson and see whats up. thanks for the help.i should have listened to marc and not dyno'd on the maha ls3000.i'm sure the long dyno runs and set up didnt help the temps much
    Apr 05 2007
    yeah it still shouldn't kill it that much, i agree! see if you can find someone local with ECUx and do a good 3rd gear log to see what's going on.
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    Intercoolers?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    stock intercoolers. i probably just heat soaked and had some fuel enrichment going on because of temps. I guess i better get this front mount on and stop dynoing in 100deg temps lol
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    which tune?
    -Luis
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Why did you take the graph down? And why did you change your sig from saying marc10sec fueling kit to now saying its just stag3 with 60lbs? Wierd....
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Quote Originally Posted by exorcet View Post
    Proof was viewed by my eyes beating a Supercharged E46 M3. Stage 3 AA with meth injection. We did 3 runs and I pulled each time. That's enough proof for me.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Quote Originally Posted by S4 in_lowplaces View Post
    Probably because there is only 1 person offering any real help in here and everyone else is doing what your doing and trying to deface marc .I've pretty much figured out through people in pm's about whats wrong.
    Apr 05 2007
    with some false preconceived notions existing regarding marc's kit, a Maha dyno pull with 101 degree ambient temps, 91 octane, stock intercoolers and 22psi doesn't prove anything to anyone. i would guess it would be to keep this thread in a positive helpful discussion rather than turn it into a shit slinging contest.
    Justin - i can't agree more. C6 Z06's.. E60 M5's.. all day every day. Street proven.
    Nov 01 2005
    S4
    VA
    whether it's the tune or not (probably not) i think it's funy cuz people act like no one ever has issues with other stage 3 tunes.
    I HAVE MARCS TUNE, I DON'T THINK THATS WHAT THE PROBLEM WAS
    -Luis
    Mar 14 2007
    michigan
    I'm glad we got that cleared up
    Dec 06 2007
    Calgary, AB, Canada
    ECUx logs will reveal the secret.
    Mar 14 2007
    michigan
    Maybe him or some else dont wont the LOGS to be REVEALED
    Feb 09 2006
    Huntington Beach
    Cool, I was just wondering.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i dont have ECUx but will be using it on saturday when i go on a drive and the guy letting me use his laptop said he would email me the logs when he gets home so hopefully i will have them on sunday
    Apr 05 2007
    mbc capping at 20. 91 octane, 2 pulls with ~20 seconds of cooldown. IAT's started ~105 peaking 135 on RS4 IC's.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i have no idea what im looking at lol
    Apr 05 2007
    jordan and shawn do.
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    sucky dyno day
    Hopefully Ecux will work on your car its so tempermental with mine.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    thanks for letting me use it on sat jimmy
