Results 1 to 16 of 16
    Jul 13 2008
    Nova Scotia
    New to S4's have some questions for you all.
    Hey fellas,
    Just traded my 2004 A4 1.8T for a 2000 S4 and was hoping you guys could answer a few questins for me.
    The S4 I have now has GIAC software and neuspeed exhaust. I am looking to give the car a little more of a growl and was wondering if an intake will give me that.
    On my old 1.8T I had a Forge DV and a carbonio intake and I personally loved the noise it made during shifts. ( I realize not everyone likes this, but I do )
    So I guess my main question is what kind of intakes do you guys put on your cars? Just K&N filters? or is there a nice car specific intake like carbonio?
    Next, will this car with 2 DV's and an intake make a similar noise that my 1.8T did during shifts? Seems like you hardly hear the turbos in this car.
    I've done a little reading on this KO4 swap tat people do and was just wondering how much more power one can expect from just upgrading the turbos and nothing else (unless there are things that are required for the swap).
    Sorry to ask so much all at once, i'm just so excited about my new car.
    Oh crap one more question, when purchasing the car, there was 2 little drops of wet spots just below the turbo I assume oil from the turbo? I managed to get $2000 off the original deal, which is enough to get me another turbo anyway. But how much longer can I expect this thing to last?
    Thanks for your time
    Oct 31 2005
    Ashburn
    Re: New to S4's have some questions for you all.
    Your best bet is to use stock intake and do what we call DARINTAKE mod.
    If you want to hear the turbo's more do piggies/downpipes.
    How many miles on the car?
    Hard to tell how long the turbo's will last, but with 2,000 def get K04's
    And you need a drop.
    otherwise nice Laser red
    - Instagram: @Sinister_rs5-
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    depends how well the turbos were taken care of and how well you take care of them, and how many miles are on the car
    Registered Member Two Rings Skydive@AI's Avatar
    Mar 14 2008
    Audi S4 Avant, GMC Syclone.
    Woodland Hills, CA
    As the previous poster indicated, the Darintake mod is quite popular. Additionally, the X-1/SDR Research Intake has proven quite nice, and is popular with people who upgrade turbochargers. It's a custom Carbon Fiber/Fiberglass Intake which seals against the bottom of the hood, and contains an AEM Dryflow element, which does not require K&N style oiling that can damage your MAF.
    You'll probably want to take your car and have it looked at my a good independent Audi tech. If your turbos are leaking oil directly, it's quite likely that they won't last long. Start saving for K04s or better. (Turbo replacement requires and engine pull, and substantially more cost than the A4 work.)
    Good luck!
    -Michael
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    that red is the brightest i've ever seen... looks good.
    first of all, do a little searching, everything you've asked has been asked soooo many times. The FAQ and DV stickies are very helpful when it coems to your questions.
    but anyways, 2 grand should cover some maintenance for a year (unless you do your own).. save up for the big blow, and for some k04s, or bigger :).
    say no to the intake. they are too expensive and perform no positive function on the car. Darintake will suit your needs.
    As far as DVs, get whatever you want, they do the same thing. coming from an a4 you must know how BOVs are bad.
    Downpipes or piggies are pretty much necessary.
    good luck with this car man... you'll need it
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    K04s can get you anywhere from low 400s to high 400s chp. And right around 500 on race gas.
    I feel mine on k04s, fueling, and the rest of my mods feels right around 450+.
    K04s are the most easy stage 3 turbos to go with for tuning and less modification wise. Not the fastest stage 3, but good enough to hang with $150,000+ performance cars.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Jul 13 2008
    Nova Scotia
    Thanks for the responses guys.
    The car has 125,000KM on it. The timing belt was changed at 98,000. I hear some people say change it every 60,000KM is this to early?
    What is involved in installing these "piggy pipes" does the engine have to come out for these as well?
    Also, are downpipes and piggys the same thing? sorry if these are retarded questions. I'm used to vwvortex where the search doesn't work. Sorry about that, i'll search before asking next time.
    Jan 29 2007
    08 S4 00 S4
    MD
    Piggie pipes are taking the stock downpipes out, gutting the warm up cats(the ones that sit behind the turbos) and relocating the secondary O2 sensors behind the main cats so you don't get codes. Some use anti-foulers in the stock secondary O2 bung locations, others cap off the secndary location and reweld new bungs after the main cat. It's one of the harder DIY for this car, in my opinion.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Nice looking car. Just need some coilovers to get rid of the 4x4 look.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I love your rims! and I agree with JungbS4, that is a bright laser red. I usually dont like the laser red look because it comes accross orange in pics,
    but yours looks awsome!
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    detailing in direct sunlight!!! ur nuts sir.
    lol
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jul 13 2008
    Nova Scotia
    Quote Originally Posted by JDM EJ1 95 View Post
    lol
    Lol.. I know what you're sayin' man, but my direct sunlight that day was like 13 degrees.
    Another quick question for you guys while i'm at the computer... My car has a GIAC chip and a Neuspeed exhaust, I'm pretty sure that all the modifications done to it so far. So does that mean my car is Stage 2?
    What kind of power/torque would this thing put out at the crank?
    Thanks again fellas, have a good one.
    Jul 06 2007
    San Jose, CA
    13 degrees! I take it summer there just means no snow?
    Feb 28 2007
    chicagoland
    im guessing 13deg Celsius
    Nogaro 01 s4
    620whp 93octane
    Oct 31 2005
    Ashburn
    Quote Originally Posted by Frauzel View Post
    Yes you are Stage 2
    Not sure bout power but i'll guess 330hp and 370tq all crank numbers
    Veteran Member Three Rings AWD87's Avatar
    Nov 23 2007
    01 S4
    Midwest
    What size are those wheels? 19"s?
