Results 1 to 7 of 7
Thread: Starter failed?
    Jul 08 2007
    2007 2dr 6spd gti
    Hillsborough
    Starter failed?
    my moms 2007 s4, less than 40k miles on it all of a sudden wont start, we have never had problems with it before and its always been on time to services and is 200 miles from its next one, but now when i try to start it it just turns over but doesnt engage, im tempted to think its a type of security feature that doesnt allow it to start if something happened but not sure because this would be the first time for it, if anyone has any idea of what to do please feel free to say so, thanks in advance
    Jun 02 2008
    Orlando, FL
    Re: Starter failed?
    Should be under warranty. Call the dealer.
    Dec 05 2006
    So. Cal.
    Re: Starter failed?
    Alright, it's not the starter it's the alarm. Get out of the car and lock it with your key fob. then unlock it, again with the key fob. Get in the car and start it up. It should work.
    If this doesn't work, then my apologies, but it's not the starter becasue if it was, it wouldn't crank at all.
    Jul 08 2007
    2007 2dr 6spd gti
    Hillsborough
    Re: Starter failed?
    hm so lock then unlock, then lock then unlock and get in? and it should start? cuz i tried and didnt work but mabye i didnt do the right sequence
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Re: Starter failed?
    By turns over do you mean the engine is turning over, or is the starter just turning and not the engine ? If the motor is turning its not the starter , you have a problem with your ignition system . If the starter just spins the windings are fine but the starter gear is not engaging the flywheel because the bendex solenoid is NFG. It's an 07 get it to the dealer and tell them to fix it .
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Re: Starter failed?
    Out of gas?
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
