Results 1 to 7 of 7
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Missing Lower radiator Retaining clip...URGENT!
    Couldnt find anythign concrete on search. My lower radiator hose retaining clip (The one that holds the rad hose to the radiator) on the radiator hose came off somehow and is missing in action, i dumped all my coolant and cant clip the hose back on. I want to take the clip off my A4 for now til i can get a new clip, i just need to know of the clips are the same and will work?
    Also does anyone have the part number for the clip?
    --Black 2001.5 -S4- 10secS4 Tuned
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Missing Lower radiator Retaining clip...URGENT!
    Which clip?
    Senior Member Two Rings u7401087's Avatar
    Feb 24 2006
    Indiana
    i believe its 34a in ithe pic....
    RS4 grill~custom widebody~M3 style lip~DTM Kreuz 10
    Dynaudio~Xtant~
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by u7401087 View Post
    1J0-121-142
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    yea i gathered that, are the clips on the S4 and the A4 the same? i took one off my A4 til i can get to the dealer tomorrow, i just want to be sure its the same before the hose pops off again.
    Jan 12 2008
    WV
    I lost my upper radiator hose retaining clip when i did my TB. Luck for me the Hydraulic TB tensioner clip (that holds it compressed during shipping) is the same diameter wire. I was able to bend it close enough to fit in there (I used the lower retaining clip as a model). I bet you can find some wire the correct size and make one. Good luck.
    Quote Originally Posted by Grangalan View Post
    Dec 06 2007
    Calgary, AB, Canada
    ^2nd, it's not exactly a high-precision part. Just as long as the new clip looks like it's the same dimensions, it should work fine.
