    Aug 17 2008
    93 S4
    Michigan
    93 S4 possible bad steering rack and other things
    While driving my 93 S4 two weeks ago I noticed a thin cloud of blue/gray smoke trailing the car. I got home, popped the hood, and noticed fluid all over the firewall, passenger inner fender, back of the engine, and right side of the transmission. A lot of fluid hit the exhaust also, good thing it didn't catch fire! The passenger side steering boot is split right next to the outboard clamp(closest to the pass. fender). I also noticed fluid inside the boot. Is it possible that an internal leak filled the boot causing it to split and spray the engine bay with fluid? Is it time for a new steering rack? Has anyone replaced the rack themselves? If it's not too difficult I'd like to do it because a local Audi dealer wants $1650 just for the rack. I can only imagine the cost of labor.
    Also, it's time for the timing belt/water pump to be replaced. How much is that going to cost.
    Any help is appreciated.
    Oct 14 2006
    by the lakeshore, mi
    Re: 93 S4 possible bad steering rack and other things
    here is a rebuilt rack for $814.95
    where in MI are you located?
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
    Aug 17 2008
    93 S4
    Michigan
    Shelby Township
    Veteran Member Three Rings BING's Avatar
    Sep 18 2006
    01' A4 2.8QM ,99' A8Q,93' //S4
    comin up fast on your left !
    I replaced my rack when i had the engine out(very easy access) but it can be a pain with engine in.. I got my rack from www.worldimpex.com for $350 shipped,rebuilt of course. When the boot rips and the rack leaks you et the green goo everywhere, make sure you clean it very well,its corrosive..... Also try www.germanautoparts.com and www.sjmautotechnik.com call them too for parts..
    REMEMBER..when installing rack put key in ignition and unlock wheel for a easy lineup of steering column to rack spindle !! if you forget you will go nuts tying to get them to mate ....
    03' VW TDI in GTI clothing
    93' //S4 GT30/40R,VEMS,6MT(sold)
    99' A8 4.2Q(sold)
    01' A4 2.8QM(sold)
    02.5' VW Passat Wagon 1.8t
    110 valves =;^)
    Veteran Member Three Rings chucka4's Avatar
    Feb 18 2004
    1995 audi s6
    pittsburgh pa
    some one is selling a rack on audifansmarketplace for 150 i think. its at least worth checking out. http://www.audifans.com/marketplace/..._Parts&id=9162
    1996 audi a4-gone to a airplain malfunction
    1998 audi a4-sold to a simple farm boy
    1990 audi CQ-dont buy a car that is not from the US
    1990 audi 100-mistake and distroyed
    1995 audi s6- the new hawtness of sexytown
