Results 1 to 3 of 3
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    single satellite radio antenna to a dual antenna adaptor?
    Where were you guys purchasing the single to dual antenna adaptor to use the newer satellite boxes with older dual antenna leads?
    Jacksonville's Premier Paintless Dent Removal
    Got A Ding? Give Us A Ring!
    904.705.DING (3464)
    http://www.dent-technique.net
    Aug 09 2007
    2004 A4 1.8T Quattro Tip USP
    Portland, OR
    Re: single satellite radio antenna to a dual antenna adaptor?
    I just ran the sat signal to the unit and my reception is fine...not sure if it is either
    1) ignoring the terr signal or
    2) joining the signals at the receiver level like some of the old units used it.
    for more info, i have avic-z3 w/ XM and i used my OEM XM sharkfin antenna wires found in the trunk.
    USP CLUB MEMBER #75
    Jun 17 2004
    having a dual antenna and then using a single antenna tuner box, will it decrease my reception?
    904.705.DING (3464)
