Results 1 to 22 of 22
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    Are these the right pistons to get?
    http://cgi.ebay.com/ebaymotors/Audi-...mZ320112117417
    thanks.. if u guys can let me know if these are the right pistons i need.. and what are the matching rods i would need for this.. thanks again!
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    Re: Are these the right pistons to get?
    anybody?
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Those should work and you would need to get some Scat rods with 20mm wrist pins. You wouldn't need to upgrade the pistons if you're still just going with the GTRS. You could do just rods for some insurance if you wanted.
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    well was going to do the rods and pistons.. for the 3076 if i ever changed my mind.. u know? i figured.. hell... if im gonna do rods for a little it of security.. might as well do pistons... then the ARP studs. u know.
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I guess you might as well do it while you're in there.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Romell, unless your pistons are damaged or you are increasing your bore size, there is no real reason to replace them.
    If you are looking to strengthen the bottom end of your motor, you can go with Integrated Engineering forged rods and retain the OEM pistons.
    The rods can be replaced in your motor without removing it from the car, just make sure you use the correct rod bearings so you do not have to do it twice. The IE rods are designed to work with OEM Audi TT225 rod bearings.
    If you are palnning on upgrading the rods, while the head is off the car, I would upgrade the exhaust valves too.
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    so i get the audi tt225 rod bearings and the ie rods and just drop them in or what? caused i dont know what exactloy to get and etc etc. can someone ehelp me with that... and with the stock pistons and the IE/Scat rods at 19mm that can def handle GTRS boost at 25 lbs right? and second could that handle a gt3076 or gt3071
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    and bout the pistons... are thos OEM pistons.. or some cheap chinese made knockoffs
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Yes
    Oct 29 2005
    10speed
    San Francisco, CA
    Romell, dont worry about the pistons... Get IntegratedEngineering rods, new rod bearings and an OEM ringset
    - Clint
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    great advice
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    cool.. exactly which ones do ineed.. which rods.. which bearings and which ring set. can u tel me exact sizing and etc. and what else iw oudl need to complete the install... should i get the ARP studs that issam is selling also? and new head gasets and etc?
    Dec 06 2007
    so how much do u guys think this will all cost??
    -Kirk
    BetaAlphaTau Member #58
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    hopefully not a lot....
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Quote Originally Posted by romell View Post
    Hey Romell, I'm going to do a GTRS with rods also. I was looking on genuinevwaudiparts.com on this is what I got. And wondering am I missing anything?
    piston rings ( 1 piston) $76 x 4 = $296
    tt rod bearings $18 x 4 = $72
    IE rods w/ 19mm wrist (set) =$380
    total for parts = $748
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Quote Originally Posted by FourRings80 View Post
    There is no way the rings for just one piston are $76
    I remember someone buying the whole OEM set for about $92
    -Sami-
    Dec 03 2005
    2 pedals 1FG
    connecticut
    That is about how much they cost for the TT225HP model. I'm not sure how much they cost for the B6 AMB.
    -Doug
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    I know it sounds expensive for 1 piston, I coudn't find a piston ring set for the 1.8T and for the 3.0L it says: "Includes rings for one piston" = $78. So I assume the $76 in the 1.8T section is for one piston also. Maybe I'm just retarded or something...and the tt rod bearings are $8 for 1/2 a bearing.
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Oct 29 2005
    10speed
    San Francisco, CA
    Martin, you can find cheaper rings, and I would step up to coated rod bearings
    - Clint
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Clint, I asked Eurocode about this and they said for my setup there wasn't any reason to go with the coated bearings. They said the stock bearings will work just fine.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I don't have coated bearings in my engine.
    -Doug
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Yeah, dont think its necessary. But hey for $40 it might be a good idea. 034 have piston rings $44 per piston. Your're right Clint I'll look for cheaper places.
    http://www.034motorsport.com/product...5s853nlliogbq4
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
