Results 1 to 12 of 12
    Senior Member Three Rings ad03avant's Avatar
    Jun 21 2008
    2003 A4 Avant Quattro
    Olympia, WA
    DIY Blackout Grill or Black Matte Grill
    I did my grill up like on a4 mods. I washed my car today and just noticed that the DIY grill is peeling. I used almost a whole can of the rubber stuff when doing it. Is it my own fault for washing it, rubbing etc? Now that I have usp front should I just buy a black quattro grill or redo the current one. Could it be possible I didn't sand enought - used 100 grit?
    Ideas, Suggestions, Other?
    D
    Andy
    -2003 A4 Avant Quattro
    -APR Stage 2 +, Achtuning Snub, Avic D3, USP Front, S4 blades and bi-xenons, APR stealth, 034 HFC, ASA JH3 18', platinum VMR sport gauge, h-sport sways, ABT springs, Koni sports, Zimmerman sport rotors, Stoptech stage 1
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: DIY Blackout Grill or Black Matte Grill
    After sanding it did you clean it thoroughly?
    -Sami-
    May 24 2007
    Southern California
    be gentle to it. its fragile stuff.
    you can peel all of it off in 2 minutes. then respray.
    i take them off from time to time to spray locally where it peels.
    Kyle
    2.0L Revo GTRS Eliminator
    Jun 21 2008
    Olympia, WA
    yeah I cleaned it really well. Washed it in the sink with gentle soap. I was clean. My coats took place over like 2 days or so. I guess I can respray pretty cheap in the mean time. I just dont want to have to do this every couple weeks or so. Its totally ok for the meantime, but am I messing up or if I want it to last for the long haul should i but a blacked out grill..?
    My lower is the same, but I dont hit it because I think I fu$ked this one up by hitting during hood washing.
    D
    Andy
    May 24 2007
    Southern California
    it only takes me about a half an hour to spray the grille.
    i wait about 1-2 minutes between each coat.
    do a good amount of them. (around 10 medium coats)
    let dry for another 30-60 minutes
    when i say "gentle" i mean avoid accidentally hitting it with a hard object. etc. after its dried.
    i havent resprayed my top grille for a year. and its still perfect.
    but i resprayed my lower once. it only had one or two micro rock chips.
    im OCD though and i hardly drive it.
    Kyle
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The most important parts of the process are to make sure that you sand ALL of the chrome finshe on the grill until it is dull (gives the plastidip a surface to adhere to and then to clean the entire trim ring with laquer thinner and let air dry thoroughly.
    Use many light coats in favor of heavy coats and it will turn out wonderfully.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    And don't use a whole can, the thicker it is the more likely it'll peel. 2-3 light coats should do it.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Senior Member Three Rings notob6's Avatar
    Nov 23 2006
    B6 a4 1.8t
    Chicago
    if you're sure that you want it black then just prime it and spray it black. thats what i did to mine and it came out a lot better.
    Jun 21 2008
    Olympia, WA
    Im getting sick of redoing plastic dip. Did it today and it looks sweet, but I should just pony up and buy the damn 88 dollar grill...
    Andy
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    i used flat black paint on all of my grills and its been over 6 monthes, washed many of times, been thru a drive thru wash or 2 and no peeling or chipping at all. also did my mirror caps, the under trunk trim piece as well, and its all still intact...
    plasti-dip FTL
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Senior Member Three Rings mtshank's Avatar
    Mar 26 2008
    B6A4 | 01 V70 | 73 Jeep Commando
    Salmon Creek, WA
    looks good
    | UNITRONICS | FORGE | H&R | BILSTEIN | TECHTONICS | BORLA | BOSCH | LAMINIX | MATRIX INTEGRATED | A.S.S. |
    The Northwest's Premier Audi Group
    BLACK DOORBLADE ALLIANCE MEMBER #4
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Upper is $85 however the lower for the USP is $195
