Results 1 to 26 of 26
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Rewrapping door armrest inserts... whos done it?
    So on my door armrest inserts, the leatherette has come un-glued from the card, and now it is all bubbly. I am considering re-wrapping them, maybe alcantara. I know a couple of people have done it, but couldn't find anything searching.
    Also, I pulled off the inside of the door, and that insert is heat-welded in. Once I take that off, what are you guys using to re-attach it? TIA
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    Re: Rewrapping door armrest inserts... whos done it?
    Quote Originally Posted by big_greasy_taco View Post
    Once you cut off all the plastic heads carefully so that you leave enough of the stem so that when you put the insert back on you have something to grab onto. I have not put mine back on yet but I was going to use either epoxy or plastic weld. I do not suggest hot glue as I think it will break off if you put enough pressure on the armrest.
    My CF center armrest was hot glued on and it came off so I used epoxy and I don't think it will ever come off again .....
    As far as what material to use, that is a matter of personal choice.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I was considering making a mold off of mine and making a new set out of fiberglass.
    That way instead of the fabric material being there I could make it a high gloss black, like a piano black or something like that.
    Apr 28 2008
    Houston, TX
    Quote Originally Posted by djwimbo View Post
    carbon fiber would be sweet too!
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    ill be doing mine soon in plaid...same as my headliner.
    Apr 28 2008
    Houston, TX
    Plaid? what original interior color do you have? I wanna see some pics
    Does anyone know where to buy alcantara stateside for less the $130 from gulffabrics.com?
    May 07 2007
    black sport cloth interior
    same plaid as my slider...entire headliner is out and being done in it as well
    Aug 16 2008
    North Carolina
    Talking Re: Rewrapping door armrest inserts... whos done it?
    Plaid? Interesting choice and unique. Looking forward to seeing that. I also would like to redo the cloth inserts to my A4 so I'll be monitoring this post.
    Apr 28 2008
    Houston, TX
    Quote Originally Posted by unorthodoxa4 View Post
    What did you have done to the headliner in this pic? Looks good.
    Dec 30 2007
    wilmington nc
    hey how much fabric did you use? also how much did you get it for?
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    heres mine, blue tweed on santorin......i think i'm gonna go ultrasuede or alcantara myself
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    May 07 2007
    in that pic i have black suede and purple plaid slider...the suede sagged though. its getting replaced with the plaid now. i had alot of extra suede from what i bought, so im not sure exactly how much i used.
    Apr 28 2008
    Houston, TX
    Are you doing it yourself of having someone do it?
    Aug 16 2008
    North Carolina
    Thumbs up Re: Rewrapping door armrest inserts... whos done it?
    Quote Originally Posted by boostedup View Post
    The blue tweed looks great. Ultrasuede makes for easy clean-up and looks good. You guys need to write up a how to for changing panel fabric with pics. Hint Hint...
    Registered Member Two Rings Fuzz_Duster's Avatar
    Apr 15 2008
    Scottsdale/Prescott
    http://www.discountfabricsusacorp.com/suede.html
    2004 subaru wrx
    Greddy/HKS stage 2.
    Apr 28 2008
    Houston, TX
    Quote Originally Posted by Fuzz_Duster View Post
    OOH nice, have you tried that ultraseude yet?
    Apr 15 2008
    Scottsdale/Prescott
    no I haven't. I just ordered some swatches from ultrasuede.com to see if I can get a match on my alcantara shift boot. Then once I find the exact color name and number I'm planning on going through the link I posted.
    2004 subaru wrx
    Greddy/HKS stage 2.
    Oct 06 2004
    Minnesota
    Ultrasuede on the door cards and arm rest will look like crap in no time. Trust me
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Apr 28 2008
    Houston, TX
    Quote Originally Posted by A4Rob View Post
    I was somewhat worried about sun and rubbing. Have you had any luck with another material?
    Aug 16 2008
    North Carolina
    Question Re: Rewrapping door armrest inserts... whos done it?
    Are you sure your talking about real Ultrasuede and not regular Suede? They use Ultrasuede in high end luxury yachts because it's water & stain resistant. Resistant to fraying, pilling, stretching, and shrinking.
    http://www.ultrasuede.com/products/t...tation/marine/
    May 07 2007
    doing it myself
    Aug 16 2008
    North Carolina
    Cool Re: Rewrapping door armrest inserts... whos done it?
    Any updates on changing fabric inserts? Trying to decide if I want to tackle this or have a guy that does headliners do it for me.
    Veteran Member Three Rings AudiTurrbo19's Avatar
    Nov 12 2006
    2004 Audi A4 Avant USP
    Middletown, Connecticut
    Just did my door cards in black micro suede yesterday...was a little bit of a pain to get the card apart to re-wrap it but not unbearable. I used super 77 to glue the new fabric on over the old, seems like it sticks pretty well, time will tell. To secure the card back together i used plastic specific epoxy. Any more questions PM and ill try and answer them.
    Apr 28 2008
    Houston, TX
    Quote Originally Posted by AudiTurrbo19 View Post
    and the picture are where? The only thing I am worried about with micro suede is durability. It doesn;t seem very wear-resistant
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by SuperStuff View Post
    Digging up some old posts:
    Quote Originally Posted by onemoremile View Post
    Ultrasuede and Alcantara are the same thing made by the same company.
    Ultrasuede is made by Toray Ultrasuede. Alcantara (technically, Alcantara Automotive Products) is the brand name for the automotive market and Ultrasuede covers the aftermarket, commercial, marine, and everything else.
    http://www.gulffabrics.com/ is the authorized US distributor.
    http://www.ultrasuede.com/where_to_buy/index.html
    "All ultra-microfiber products for automotive applications are branded Alcantara® worldwide."
    http://www.ultrasuede.com/where_to_buy/automotive.html
    Below is our list of distributors and retailers who carry Alcantara® for automotive aftermarkt applications. Be sure to check this list from time to time since we update the contents frequently.
    Cut Yardage in the U.S.:
    Gulf Fabrics
    813-875-2707 (tel)
    813-348-9540 (fax)
    [email protected]
    www.gulffabrics.com
    Roadwire
    2930 Vail Avenue
    Commerce, CA 90040
    1-877-ROADWIRE (toll free)
    [email protected]
    www.roadwire.com
    Star Motoring Inc.
    241 S. Van Brunt St
    Englewood, NJ 07631-4009
    201-567-4050 (tel)
    201-567-1229 (fax)
    www.starmotoring.com
    Cut Yardage in Canada:
    Pro Leather
    8829 Heather Street
    Vancouver. BC Canada V5P 3T1
    604-325-7250 (tel)
    800-646-0674 (toll free)
    800-572-4506 (fax)
    www.proleather.com
    Replacement Interiors :
    If your new car does not come with an Alcantara® interior or you want new seat covers for your current car, check out Roadwire, the industry leader for replacement leather and Alcantara® interiors.
    Roadwire
    2930 Vail Avenue
    Commerce, CA 90040
    [email protected]
    www.roadwire.com
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    I'm doing that this weekend. I've got one of Mike's door panels in the back of my car and want to grab the other front and maybe the rears today. If I had help then it would be very easy to do all four. We're running the Cobra at Grattan Saturday so it would probably be tonight or Sunday. Some of those super secret details we discussed will probably get worked into the mix.
    I'm going to stop by the hobby shop and see if the spray on mask would work well. I could spray that on the face and get a much more consistent thickness and better finish in a fraction of the time compared to taping or tin foil.
    Jim
    I Do Werk.
