Results 1 to 11 of 11
    Aug 15 2008
    Nashville, TV
    Question Did ALL B6 A4 1.8Ts come w/ HID
    I just got an 05 1.8T which has the HIDs. However, during the first nighttime drive, I was surprised to learn I could barely see without the brights. Next day, I pop the fuse box and notice there is not a fuse in Slot 10, which is the one for the automatic leveling which is required for HIDs. Get a fuse, put it in and it falls out. I look in there closer and note there are NO contact points. Essentially it's a vacant slot like #18.
    So my suspicion is that someone swapped out non-HIDs with the ones in there now, not realizing there was a CRITICAL component missing. But that theory depends on whether or not non-HID cars were offered.
    If this is the case, how difficult is it to get these things wired correctly so that they work and are actually useful?
    I'm extremely aggravated, as this has completely blown the whole new car (to me) excitement thing.
    Thanks for any answers and advice.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Re: Did ALL B6 A4 1.8Ts come w/ HID
    HID lights were an option, not a standard in A4's. You probably just need to adjustment the beam height and that should bring your excitement back.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    No, they didn't all come with it. But I don't know that you HAVE to have the leveling in order to have it either. Mine came with it, but there are people on here who have swapped them out.
    If it does have xenon you should have been able to tell very easily. The telltale color change during warmup when you first start the car is the dead giveaway. But not having the auto-leveling should have nothing to do with the xenon lights working and being bright enough. Do you have any pics of your car?
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    This was one of my first questions before buying my A4
    The answer is No
    What I did, and what you can do is, contact memeber "akinaboy". He will hook you up with an OEM xenon retrofit kit. I think mine cost about $300 and it came with (2) ballasts, (2) ignitors, and (2) D2S 6000K bulbs. And by god, are my lights bright now. This kit isnt some ricer, blue bulbs. It is the same components, that came on the A4 with xenons.
    I love em. By far the best money spent on my car.
    -Sami-
    Jun 28 2008
    Yeah, that was one of the first things that I checked when I bought my car too. And if you don't have em, get em. $300 isn't bad either.
    -Damon-
    Aug 15 2008
    Nashville, TV
    Thanks for all the quick replies. Here's the deal - it DOES have xenons (my second Audi so I know THAT, at least :-) ). They just aren't providing any light down the road - only, it seems, about 40 feet.
    Let me ask you guys this question - when you turn yours on, say in the garage, do you see them move up and down, briefly, adjusting themselves? If so, that's the self-leveling function I'm talking about, which as I understand it IS mandatory under federal law. But I'm going to look into that again. I just have to get them adjusted in the interim so that I can at least see at night without blinding everyone w/ my brights.
    Aug 26 2005
    Quote Originally Posted by urgeasaurus View Post
    Auto leveling, only adjusts for load variation, to prevent the beam angle from shining in oncoming driver's eyes if the car is loaded with pax or payload in the rear. The range/beam angle, is based on the settings made manually according to standard beam aim angle adjustment references.
    For non auto leveling retrofits, using OEM HID parts, if the beam aim is set correctly as baseline, there is NO difference between setups with or without Auto leveling, and HID range or amount of light provided. If a large load is added after setting the beam aim, then either do so during daylight, or lower your beam angle to compensate.
    Sounds like your setup, is aimed to low, the cutoff should be 2 inches below the horizontal height of the headlight centerline, when the headlights are 30 feet from a vertical target. The Knee in the kick up of the cutoff, is set with zero lateral offset from the headlight center line at the target.
    Finally, it's possible to retrofit the auto leveling setup, but it's not easy, and is not worthwhile as a practical matter.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Great info^^^ so wish I had HID but perhaps one day.
    Aug 15 2008
    Nashville, TV
    Diagnoticator, thanks for the great reply. That's exactly the information I needed and also eases my mind. I was worried I was going to have to get into a very involved retrofit auto-leveling thing (or pay someone, actually).
    Thanks again!
    Aug 26 2005
    Thanks again!
    No problem! One other aspect for you to consider, is that instead of auto leveling, manual leveling can be implemented using factory parts. This is a lot easier to install, using less complicated hardware and practically no electronics. The manual beam leveling uses standard DC motors instead of the stepper servo motors used in auto leveling, and a simple control knob that fits near the headlight switch. The beam angle motors, fit the headlights just the same as the auto leveling setup. The control action is simply running the motors in one direction to raise, and the opposite direction to lower the beam angle. The wiring from the control knob is two wire circuit, with the two motors in parallel connection. The control shifts the polarity of the drive voltage to the motors.
    The OEM parts have to be ordered from Europe,. and are used on the Halogen type headlights. Required: 1ea control switch/knob. 2ea beam adjustment motors. The wiring harness is produced locally using terminal housings and the associated wire terminals available from the local Audi dealer parts counter. It's also possible that the existing wiring harness to the headlights, already has the wires for the auto leveling, if that is confirmed, then the wiring can be arranged to power the manual leveling motors.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    If anyone is interested, I just installed (yesterday) my Valeo OEM H7 6000k conversion kit from hidconcept.com. 10 minutes per side (including quick clear corner mod)
    All's I have to say is that I look for excuses now to drive at night! I had the halogen projector headlights, not the OEM HID's...FYI.
    Cutoff looks no different from my brothers 05 Maxima w/ OEM HID's!
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
