Originally Posted by
mtlavant
It's off an S-line 1.8t so the weight up front should be the same. The dealer is pretty useless as he can only help me with a the VIN#. He says there's like 7 different shocks and springs for the A4... Ill just try the install and see what happens. Thanks for the input on the bump stops, ill let my shop figure it out.
Just a little more info on the bump stops, I was going to buy the oem sport ones from the dealer, imagine my surprise when he said it was $64 for the rears and $38 for the fronts....and that's each, not for the pair.
Anyways, if you decide to get the oem ones, here's the part numbers you'll need:
Front: 8D0 412 131F
Rear: 4B0 512 131B
What I ended up doing was cutting the required amount off the ends and then used a bench grinder to reshape it, otherwise it's a real PITA to get it to fit back inside the boot.
Good luck with the install.
