Well I had my mind set on getting a 335 coupe right until I test drove it and decided for this time and day its not worth getting 35K in debt over a car... So instead Im going to put the down payment into going BAT... But in the meantime i decided to open up a few things while getting all the parts together for the project...
The little K03 seals was shot so my friend said well since you got to rebuild it... Why not change the front wheel and go a little bigger... HELL WHY NOT!! So i got the wheel and the turbo machine shop is putting it all together as we speak... I had to have them machine the housing to fit the new wheel under it... Im not expecting a HUGE difference... But it should make a little.. I'll let yall know.... And I decided to do a nice gasket port job on the manifold, You can see that the air was hitting a wall before and I got it down to go straight into the port (kinda hard to hold the camera and gasket up at the same time) but you get the idea.... The head is another story Im not brave enough to take that on but you have about 1/8th or so that can be opened up to match the gasket.... It took about 3 hours to do the manilfold...
Once it gets back I will put some new plugs in and got to get it re-tuned... Then it should move really nice until the 2871r or 3071r goes on....
