Results 1 to 24 of 24
    Established Member Two Rings jesterekim's Avatar
    Aug 26 2007
    2001.5 Audi S4
    New York
    Leaking Sunroof or Clogged Drain Plugs?
    Hello all, been awhile since I posted here. Hope everyone's doing well.
    I just got my driver side tie rod assembly replaced along with the axles (both cv boot were ripped with no grease, wonder how long I was driving like that for.)
    Anyways, got a slight problem. I don't know if the sunroof isn't closing properly or if there's a leakage OR if the drain plugs are clogged. I found this article: http://www.audiworld.com/tech/ext61.shtml and I think I'm going to try that first. I'm just trying to make sure WHAT the problem is. And I'm having a hard time finding speedometer cable ANYWHERE. Been to Autozone and R&S Strauss, and they have nothing. Anyone recommend me something similar to the speedometer cable that I can fish thru the drain plugs?
    Also, check these pictures out. The rear pillars on the driver side gets wet after a carwash and carwash ONLY. It rained pretty hard a few days ago and I was driving around for 2 hours in the rain, and the pillar was dry. WTH? Anyone know anything or done something to fix this? Here are the pics.
    Thanks in advance for the inputs.
    Stage 2 | Brilliant Black | 6-speed
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Leaking Sunroof or Clogged Drain Plugs?
    mine has the same thing..
    i dont know what it is
    but i have some on the front panels too by the windshield
    autozone DOES have that cable... its located behind the counter with all the other speedo cables.. its a universal speedo cable repair kit.
    (i was a manager at autozone)
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Senior Member Three Rings RxDlr's Avatar
    Nov 21 2006
    Skokie
    I've had this same issue. I don't know if audio ever recalled those tubes you may want to check on it. I know theres a way you can clean them but if you have marks on the door pillars from the water I don't think those come out
    2007 s6 (present)
    2002 s4 (Past)
    Stage 3: VAST fueling| VAST TCU | RS4 SMIC's w/ APR hoses | milltek true dual exhaust | piggies | 710n dv's | apr bi-pipe | vogtland c/o's | hsport front and rear sways | rs4 grille | piano black trim | cc mod | EuroGEAR CF trunk and hood | RS4 reiger front | 18x8 bbs rs-gt
    Feb 28 2007
    chicagoland
    im pretty sure a light solution of water/soap will get most of it out.
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Three Rings dgrs4sd's Avatar
    May 25 2008
    So Cal
    I have the same thing and thought the guy who owned it before me was spraying salt water all over the car.
    Going to clean mine today and I will let you all know what works best.
    Senior Member Three Rings AddICTioN's Avatar
    Dec 05 2007
    Houston, TX
    I have the same as well. Was planning on trying to blow the line clean with my air compressor or try the cable thing. Anyone successfully cleared the line?
    Widebody B5 S4
    Established Member Two Rings B5swede's Avatar
    Sep 20 2006
    I have the same water marks on my C-Pillars too, the marks clean off with a sponge and water, but next time the car gets wet new stains appear. I always figured the drain plugs were clogged, but hadn't found any write-up on how to address it. Thanks, Im gonna check out the link.
    Listen to Slayer.
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Is there anyway to get an air compressor to the drain-tube up top? It could be possible to blow it out without taking off the bumper.
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by jesterekim View Post
    I have the exact same thing on all four pillars, and just figured the sunroof was leaking... The staining almost looks like a crusty salt residue, so I just thought is was from living near the ocean (salt spray, then rain, etc.). But come to think of it, I think it might only be happening after car washes, cause I wash my car A LOT... so the staining must be from the soap.
    Anyways, I'm gonna read up on that DIY to clean the lines but I would also like to know if someone has tried compressed air... IDK, but that would seem to be the easiest most efficient way of clearing the lines.
    Any updates OP?
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Aug 26 2007
    2001.5 Audi S4
    New York
    It's clear that there are many S4's with this same problem. I'm assuming its a design flaw on the drain tubes. The stains come off easily, and yes, its from the carwashes.
    Let's keep eachother posted on the problems. I will go to autozone again to seek out the speedometer wire. Good luck everyone.
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Aug 26 2007
    2001.5 Audi S4
    New York
    Quote Originally Posted by big_greasy_taco View Post
    Doubt this. The speedometer cable method seems the best. Also, taking off the rear bumper is pretty simple.
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Aug 26 2007
    2001.5 Audi S4
    New York
    Quote Originally Posted by RxDlr View Post
    Washes up very easily with soap and water. Thank god,
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Aug 26 2007
    2001.5 Audi S4
    New York
    Quote Originally Posted by JDM EJ1 95 View Post
    Can you go to my local Autozone and bitch at them? I asked the counter guy and he gave me a firm, "NO." I just have to ask for that brand or just speedometer cables?
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Feb 28 2007
    chicagoland
    use the part number.. and say its a "help" number.. off of the box in the picture.
    Nogaro 01 s4
    620whp 93octane
    Mar 08 2007
    Mr. Worl-Wye
    Hmm, that sucks. I guess I have to see where the tube is located, but I'd imagine if you can get a speedo cable to it, you can get an air hose/nozzle too... You might have to jerry-rig something, but still.
    I'll give it a go and see what happens
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Aug 26 2007
    2001.5 Audi S4
    New York
    Just went to Autozone and got the last speedometer cable they had. (Thank you again, JDM)
    I will try to fish the cable thru the drain plugs this week.
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Hi everyone, I have noticed the same problem only on the rear pillars. Has anyone gone to Audi and see what they will do about it if anything? I'm going to try the speedo cable idea and clean it up as is stands and see if this problems goes away or lessens. Theres always something keeping you busy with this car.
    May 25 2008
    So Cal
    I recently just did this DIY and it worked great. I used "Tough Stuff" from Autozone and it did and AMAZING job cleaning up the stains in seconds.
    I actually cleaned the whole headliner as the pillars looked brand new after I was done.
    I do wish there was a way to push air or water from the top drain holes down to make sure that they are completely clean. From what I could tell the accesses were hidden under the sunroof...
    Aug 26 2007
    2001.5 Audi S4
    New York
    Quote Originally Posted by dgrs4sd View Post
    That's why you have to remove the rear bumper and push the cable from bottom to the top of the sunroof.
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    if ur experiencing this on the driver side u dont even have to take the bumper off, just simply go where the 6cd changer is located, pull the hose and run the wire thru there, you can do the same in the pass side but ull have to remove the carpet panel but its better than removing the bumper and possibly giving you a fitment issue when trying to reinstall it
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by AMC83189 View Post
    daaamn, that's really good to know! I was NOT wanting to take the bumper off. On a side note, why couldn't one blow compressed air through those tubes from the bottom, up? I mean, if you can access the tubes from the rear enough to run a throttle cable through them, why not air? I'd probably opt to try both just to be sure
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jun 15 2007
    Quote Originally Posted by BITRBO View Post
    i was thinking of that but i didnt want to blow dirty shit all over my interior and if it was clogged badly i didnt want to risk blowing the drain tube
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Jun 15 2007
    oh i think i should get some reputation points for that guys...lmao
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Mar 08 2007
    Mr. Worl-Wye
    done!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
