I installed a MBC today, and I can't boost past ~13psi or so. When my N75 was being used I could hit 16-17psi @ the manifold.
To the best of my knowledge I have it installed correctly.
Does it make a difference what type of MBC I have? A guy at work said he'd sell me this one for pocket change basically. It's the Forge valve that's on ECS for $35, IIRC it's considered a bleed valve. Would the Ball and seat style work better?
I installed it like it says to, the bottom leg goes back into the TIP like the N75 did, and the opposing legs are connected to the compressor nipple and the wastegate actuator.
Did I do something wrong? Would it make a difference if I used a boost reference off the DV line, so it sees manifold pressure instead of compressor housing pressure?
Looks like this.
