Results 1 to 4 of 4
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    Sound system information
    IS there any danger in swapping out the radio unit?
    I have an 04 S4 and the radio in it is not sat ready, so i want to pop my Alpine IVA-D310 (see link) http://www.crutchfield.com/S-2Ag9d1m...x?i=500IVAD310
    and get my Sirius radio back that i miss so much!!!!
    The rumor mill tells me that swapping out the radio may cause electronic problems since some computer signals pass through the radio or something?
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: Sound system information
    There are a ton of important electronic signals that pass through your radio, including a very powerful direct current voltage which supplies power to complimentary metal oxide semiconductor devices. When applied, the direct current voltage on a polysilicon transistor will open the current path between the source and drain once the threshold voltage has been exceeded. This action then turns on another connection. Each of these switches used in various configurations form logic operations which control the reception and decoding of frequency modulated signals and the satellite receiver circuitry which decodes the GEO satellite signals.
    Enough joking around..
    1st... Do not install a single din stereo in an S4, it will look ridiculous! That Alpine will look like crap in your car. Get a double din that fits nicely into the factory position, like a pioneer avic.
    If you correctly wire the aftermarket radio, everything will be fine. Obviously if you make a mistake and connect power to ground or something of that nature then you can have some problems. There are several wire harness kits for our car, I believe I've heard some using the Metra kit.
    There are other options for satellite, ipod etc. It depends exactly on what your goal is. You may want to try the "search" function at the top of the forum as it will give you a ton of info!
    for example:
    Quote Originally Posted by likewater View Post
    The AVIC D3 has a lot of options. Are you planning to use Bluetooth? How about XM or Sirius? Do you plan on using the Ipod functions? If so you're going to need the following:
    Pioneer Bluetooth adaptor - CDBTB200
    Install Harness - Metra PR0180
    Trim - There are a few available but to make it look factory, a custom install is prefered.
    IPOD cable - CDI200
    XM Tuner (Terk) -XM Direct
    OR
    Sirius Tuner -SIRPNR2
    Smart Digital Adaptor - Check with Crutchfield for part numbers. I think there may be an all in one Tuner/Digital Adaptor now.
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Hey guys, update on this. Everything I posted above is correct except what I put about the Terk tuner. That unit will work but you will NOT get full function on an AVIC unit when using XM. In other words, none of the Preset Info or artwork for any of the stations will show. In addition if you subscribe to XM Nav Traffic (very cool feature btw), that will not work either. You must use Pioneer's tuner. Not sure about how the Terk works on Sirius but I would stay away from Terk in general.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Aug 14 2008
    09 CTS-V
    Ontario
    All i wanted was a setup where i could get satellite radio with the Audi OEM antenna but an after market head unit. Did a bit of searching and i found the Alpine IVA W205 ( http://www.alpine-usa.com/US-en/prod...model=IVA-W205 )
    This unit is pure sex!!! you can dock the Nav unit right into the radio so its neatly tucked away when its being used!!
    Now for a question i cant seem to find an answer to anywhere.... :
    Will the factory Sirius antenna come with enogh cable to go from the back roof to the head unit in the front?
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
