Results 1 to 10 of 10
    Senior Member Two Rings Fizikal S4Avant's Avatar
    Aug 03 2008
    2010 GT3, 2013 S4, 2018 Q5, 2020 Model 3
    Mill Valley, CA
    Stasis Ohlins SL or Bilstein PSS9
    I've narrowed my suspension choices down to the two above. I have a B7 S4 Avant. I just wondering the pro and cons to each. Any feedback is appreciated. Thanks.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Stasis Ohlins SL or Bilstein PSS9
    tough choice. I LOVE my PSS9s, they ride like stock and handle like a beast
    - Clint
    Marin, Ca
    I've been using the Stasis Motorsports for the last few months after upgrading from the Tracksports and couldn't be happier. I doubt you'll find that much difference between the PSS9's and the Ohlins, but I think the Ohlins might be a little better if you plan on tracking the car on a regular basis.
    Edit: Ohlins SL... I haven't tried these yet...
    Wait for Jeremy to join in. He should have some excellent feedback on both.
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Aug 03 2008
    Mill Valley, CA
    Thanks for the feedback. Keep it coming!
    Mar 27 2005
    The Cold North
    you can get the pss9 for about $8-900 less the STaSIS SL's. Both are excellent options. The STaSIS will allow you to pick a higher spring rate which can be nice. You could go with something like 750-800#F & 1000-1100# rear. The PSS9's (s4 version) are ~625-650#F&R.
    The STasis will allow you to dial out more of the inherent understeer by going with the higher rear rates. STasis will match the dampening to what ever rates you pick. The PSS9's you are going to have to deal with the rate you are given.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Quote Originally Posted by EBG 18T View Post
    Custom rates would be true on the STaSIS/Ohlins Motorsport's but the STaSIS/Ohlins SL's are a fixed spring rate--you request anything different;
    STaSIS Ohlins SL Sport coilover kit for B6/B7 S4/A4; 4 STaSIS valved OHLINS steel body CCJ Dampers dampers w/ digressive damping, height adjustable, Ohlins high performance polymer spring perches for corrosion resistance and eliminating spring “wind-up” (reduced friction), 4 linear rate Hyperco or Eibach springs (750f/1100r S4, 650f/1000r A4), STaSIS 6061-T6 aluminum mounting hardware, UHMW spring perch bearings
    You CAN request rates on the MS's;
    STaSIS MotorSport coilover kit for B6/B7 S4, B7 RS4; 4 STaSIS valved OHLINS dampers w/ external front reservoirs, double digressive damping, external damping adjustability (comfort & performance), adjustable while installed on vehicle, lightweight aluminum threaded damper bodies, height adjustable, 4 linear rate Hyperco springs, 450 lb. to 1000 lb. spring rates, balanced and adjusted on SPA damper dynamometer
    Now, onto your question....I actually haven't driven on a set of SL's yet so I can't say how they compare to PSS9's. The advantage I see to SL's is that they're Ohlins dampers which surpass Bilstein dampers. However, an advantage to the PSS9's is that they're 9way adjustable, whereas the SL's are fixed in that regard (and only ride height adjustable).
    How much track work will you be doing?
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Mar 27 2005
    The Cold North
    Quote Originally Posted by jeremy@matrix View Post
    Interesting. i thought we could pick rates on those too. I guess i misread the website. thanks for correcting me.
    2020 Chevy AEV ZR2
    May 27 2004
    Portland, OR
    Anytime.
    Jeremy Williams
    Aug 03 2008
    Mill Valley, CA
    Thanks for the break down. I'm planning on heading out to the track around 5-7 times a year. I'd also plan on squeezing in a few auto x's as well. I would like to lower the car around 1" and install 19" wheels on it (not the best for racing, I know. But they look so damn good :o) ).
    May 27 2004
    Portland, OR
    Quote Originally Posted by Fizikal S4Avant View Post
    You're very welcome.
    5-7 DE days + auto-x's is quite a bit....you may want to look at the STaSIS/Ohlins MS's then.
    LMK when you're ready for them and we'll offer you a good price.
    Jeremy Williams
