Results 1 to 11 of 11
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    humming noise???
    Normally I would assume that the tire is just unbalanced, but after swapping my set of wheels with the stockers, the humming is still there around 40mph and up. It doesnt seem to get louder, but it kinda seems a little on/off (or maybe thats just my mind). Could it possibly be the wheel bearing? Car drives straight.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: humming noise???
    from what ive read online, ill try to see if it still makes the noise making a fast turn at speed.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Sounds like the wheel bearing to me... Mines going out and it's kind of like a low humming noise, almost like engine noise.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Sep 23 2007
    deff a wheel bearing mine has been like that for a while same thing happened to me after i got my tires rotated
    Aug 16 2008
    North Carolina
    Making turns left & right at speed will work. If the noise goes away in one direction of a turn it's a wheel bearing. Make sure to buy an inner bearing, an outer bearing, and a new bearing seal. I just bought a kit for my passenger rear wheel. Can't wait for that noise to go away. It was getting in the way of my tunes.
    Senior Member Two Rings Boost_N_Grip's Avatar
    Jul 01 2005
    parts
    Wonderland with Alice
    Quote Originally Posted by biketsai View Post
    ME tooo.... damn noise is driving me crazy.....
    .....Never Follow.....
    An Eye For A Eye, Leaves Everyone Blind
    Established Member Two Rings Spirare's Avatar
    Jul 08 2008
    Upstate NY
    That IS a wheel bearing.
    Aug 16 2008
    North Carolina
    Did you get it fixed? I just installed new rear bearing and I'm loving it. No more humming noise from the rear of the car. Next up will be the clicking sound from the bearing failure on a upper control arm. The part is in transit and I'll get that sound fixed soon.
    Jun 04 2007
    Austin/DFW, TX
    For some reason, I dont hear it that muhc (I guess I dont drive more than 40mph), it hasnt got to the point where I know that is it FOR SURE. But I will know when it comes.
    thanks
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Two Rings deadleavesdie's Avatar
    Aug 04 2008
    B5 Audi A4 1.8TQMS
    Alexandria Bay/Canton
    I am having the same problem and its definately a wheel bearing. When you jack it up does the tire have any play side to side?
    Sep 17 2005
    Dublin
    I'd normally suspect a wheel bearing... But, among other things, a random and inconsistant humming that almost sounds like a faint honk CAN be a bad or backwards installed DV....
    2000 A4 1.8T
    1997 A4 1.8TQM
