guy i m in a process of doing my timing belt and water pump alone with the valve cover gasket due to oil is leaking around the valve cover gasket i think is a good idea to do the timing belt job together..but there s one question i dont know is some ppl here change there snob mount.since mine is tip. do i need to change it ?i mean is it better to change it since is right over there?any great input r appreciate.and what else should i change while i m at there..beside the timing belt,seal and pump.thank
