    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    anybody fun this fuel setup
    http://www.034motorsport.com/product...ducts_id=17937
    I assume that those barb fittings would be able to be replaced with AN fittings.
    I was planing on powder coating my valve cover red so it would be seen through the slits in my carbonio engine cover.
    But now im thinking about getting rid of my carbonio engine cover and powder coating the valve cover black and going with the new style coil cover. If I do this then I want to clean up the fuel rail area and this seem like a great way to do that. I have always liked the look of those "20v TURBO" fuel rails.
    Anybody using this?
    Sorry for the typo in the title..............
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: anybody fun this fuel setup
    Not for the B6...we do not have a FPR on the fuel rail, it is actually part of the fuel filter.
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    Then anyone using the fuel rail. I would love to run some ss hose to this to dress things up even if there is no gain in performance. As long as it will not hinder the fuel delivery.
    http://www.034motorsport.com/product...ducts_id=17882
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You can run the billet fuel rail and braided SS line if you want things to look nice and pretty.
    All you have to do is either plug the return or add a fuel pressure gauge in the opening.
    I am not a huge fan of this setup though, the tiniest of leaks can cause your car to burn to the ground.
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    haha way to scare me. Is there any reason I couldn't just put a 180 deg adapter at the end of the fuel rail and still run a braided return line. I think the thought of my car going up in flames will keep me from doing this though.
