Results 1 to 14 of 14
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    How long are factory batterys food for?... i think mine is down for the count
    been having trouble starting my 2002 A4 the past few days. but finally today when i went to leave for work the battery was completely dead, i couldn't even unlock my door with the key fob. Can i take my car to an auto parts store so they can see if it is the battery or alternator?
    How much to new battery cost from the stealership or should i get an after market one like the optima redtop?
    Mar 06 2006
    2002 A4 1.8t
    San Diego
    Re: How long are factory batterys food for?... i think mine is down for the count
    I dont think you can eat them...
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Re: How long are factory batterys good for?... i think mine is down for the count
    lol i meant good for i was thinking about food when i wrote it
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    4 years if you are lucky
    Veteran Member Three Rings Silver streak's Avatar
    Jul 14 2007
    01 S4 stage 3 AWE full kit
    Vancouver B.C.
    I'm on my second factory battery, car is a 2001 so 3 and 1/2 years for each one. If I drove the car more often I'm sure they would of fared better.
    AWE, GIAC, Stasis,KO4s, bla bla bla this is getting a bit ridiculous. I hope it will end soon.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Thanks guys. I guess my time is up then
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    It also depends on your climate, cooler areas the battery will last much longer. Heat kills!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    i have an 02 as well and i had to replace mine last week after coming back from a 2 month trip. it was showing no problems before i left, and was totally dead when i returned (which i expected) but would no longer hold a charge. oh well. kragen had the cheapest one in my area. $95 after tax.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    I would like to put a red top in my car but i don't know which one to buy. Optima's website says they don't make one for the A4
    Mar 21 2006
    Lakeland, FL.
    There is a height issue, The stock battery is shorter then the Optimas. I think you'll have the trial fit one.
    I'm back bitches!
    Senior Member Three Rings zbrock06's Avatar
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    i have the optima red top, works fine!! it's not as wide as oem but the factory bracket holds it down fine, i just put extra velcro on the bottom and it's not going anywhere.
    USP CLUB MEMBER #94
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by zbrock06 View Post
    I knew it was one or the other, in that case I think I put a piece of rubber hose between the bracket and the battery.
    I'm back bitches!
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    If you're a CPO/warranty situation, Audi might replace it for you.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
