Results 1 to 24 of 24
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    C5 A6 DIY upper grille
    Just finished my DIY upper grille mod, now matches the lowers. Trim has been painted metallic gunmetal to match future mod to all vehicle trim.
    Excuse the dirty car and missing europlate
    http://www2.snapfish.com/slideshow/A...96/t_=76649396
    let me know what you think
    I don't think I care anymore
    Veteran Member Three Rings ridelikeme's Avatar
    Jun 15 2005
    B6 A4 , Avalanche LT,
    Calgary
    Re: C5 A6 DIY upper grille
    looks just as good here as it does on eurodrivers!
    Aug 04 2007
    just showing it to a broader base, if there is enough interest I will spend the time doing up a detailed DIY
    P.S. Lovin the ladies on the hood, very tasty, um I mean tasteful
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad(old) 10 Q5 10 S4 13 S6
    T.O.
    I would like a DIY
    Established Member Two Rings wRek's Avatar
    Jul 16 2008
    Allyn, WA
    DIY...?
    Remove grille, mask off areas you do not want painted, lightly sand area to be painted, and paint.
    Aug 04 2007
    slightly more complex than that, these peices are one off, I fabbed them using expanded aluminum, utilizing stock trim, rings and Quattro badge for uppers, and using the inserts on the bottoms, the bottoms pull out just like the stock ones do. DIY process takes about 3 hours for the upper and another 3 for the lowers
    Feb 21 2004
    T.O.
    the grill on the 05 allroad (same as pre A6)
    has lines going across and the lowers grills are diamond
    Aug 04 2007
    Yup, I just fabbed them all myself to be sure that they all match perfectly. My pre-facelift A6 had the horizontal louvres on both top and bottom
    Established Member Two Rings 2000 A6 2.7t 6m's Avatar
    Jul 27 2007
    PA
    Looks good, where'd you get the mesh? I'd be interested in a write-up.
    Click for Photo Album
    Upgrades:
    APR 93 ECU -=- H&R Coilovers -=- H-Sport Swaybars -=- VMR B7 RS4 Reps in Onyx Black -=- Upgraded Sound System
    Jul 16 2008
    Allyn, WA
    Ah, I didn't realize you had fabbed the actual grille. Just thought it was a different grille with the surround trim painted.
    Looks good.
    Feb 21 2004
    T.O.
    The allroad didnt match right from the factory
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Yes DIY writr up please with pics.
    Aug 04 2007
    Sorry guys, I'm on call so I 'm super busy. I will post full write up with step by step pics as soon as I get a couple minutes
    Aug 04 2007
    Here are the full front pics, DIY to follow
    Aug 31 2007
    2001 Audi A6 2.7t
    New Jersey
    yea Ive been wanting to do this for a while, I have mesh on the lowers and wanted to make a RS6 grill for the top to match on my pre-facelift, DIY would be awesome, thanks
    2001 Audi A6 2.7t Stage 2+: Special Edition, Sport Package, Winter Package, Luxury Package, APR 93 octane program, Navigation, Bose Audio, IPP Intercoolers, APR Bipipe, 710N's, Custom 2.5" Exhaust, Piggie Pipes, Upgraded Torque Converter, Stage 2 Darintake, ABD Racing big bore intake, H-sport sway bar kit, Slotted/Drilled Rotors
    Registered Member Two Rings audiRSallroad's Avatar
    Jun 19 2008
    2001 allroad
    i have an '01 allroad and ive been thinking about trying to do this for a while so yes a diy would be greatly appreciated.
    Senior Member Two Rings Asix's Avatar
    Jan 25 2008
    Audi S5
    Bellevue, WA
    hey guys...i decided to take out all my grill pieces and do a custom RS6 honeycomb grill mod for all 4 grill pieces on the front.
    just wanted to resurrect this thread and see if anybody had any DIY's on removing the top and bottom grill pieces. Are they just held in by the clips?
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    please give a DIY , thanks!
    2004 Audi A6 2.7T
    Senior Member Two Rings Switchblind360's Avatar
    Feb 26 2006
    '01 allroad 2.7T TIP, '95.5 S6, '91 200
    Boise
    So hey, you used flattened mesh for the upper and standard mesh for the lowers? Nice. Did you go get the mesh at Mcmaster-Carr? If so, do you have the part numbers for the mesh styles you used?
    '00 Audi A6 2.7TM
    HB Nefmoto Stage 3
    '91 Audi 200 QTM 20v
    TAP Stage I
    '01 Audi allroad 2.7T TIP
    Homestyle Nefmoto Stage II, 402 Mod
    '95.5 S6 QTM 20v
    034 Stage I
    Jan 25 2008
    Audi S5
    Bellevue, WA
    i got it on ebay the honeycomb grill powdercoated black. The bottom foglight grill pieces are gonna be interesting.
    2 projects coming up soon. LED headlights (S5 style) and RS6 style grills.
    Veteran Member Three Rings autophiles's Avatar
    Aug 25 2004
    '04 Discovery SE
    Wilmington, NC
    Quote Originally Posted by Asix View Post
    I'm eager to see how both of these turn out. Keep us updated.
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    link to ebay seller or product? I have been wanting to do this for a while but I cant ever find the right looking mesh...
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Nov 19 2008
    Florida
    I actually done this for my AR, I carbon fiber wrapped the bezel and plastic dipped the grille. My fab work was pretty good, but I should of primed it before p dipping.
    Jan 13 2012
    Here is a DIY which uses a ABS printed mesh.
    https://docs.google.com/file/d/0Bxju...lIUnB4UU0/edit
