Results 1 to 21 of 21
    Mar 05 2008
    Pittsburgh
    Lurker for a while Quick dirty pic
    Car is dirty as hell but i had my camera in my hand n decided to post a pic up...not a usually picture for me... im coming from my mkv gti and i used to take tons of good pictures of it... soo hopefully soon ill get some nice ones up here
    wheels are the auto art vys
    Established Member Two Rings tileg's Avatar
    May 01 2008
    Philadelphia
    Re: Lurker for a while Quick dirty pic
    bada$$
    Sep 20 2006
    B7 S4 Avant - Oettinger
    nice wheels what are those?
    Deactivated Three Rings
    Apr 11 2008
    Quote Originally Posted by egyptfolyf View Post
    FAIL
    Nov 12 2007
    Stamford, CT
    nice ride
    gotta love Pittsburgh...$1 16 oz. beers.
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    BEER!
    my contribution to the thread.
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Mar 05 2008
    Pittsburgh
    auto art vy 19x8.5 and 19x9.5..more pics soon just washed the car
    Aug 11 2008
    Calgary
    Quote Originally Posted by ttr250 View Post
    I think you rears have too aggresive of an offset...looks like they stick out too far?
    Also does the stagger effect the ESP or the Quattro system at all?
    Nov 12 2007
    Stamford, CT
    I didn't know you could stagger the wheels.
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    how do you like the autoarts im looking at vyc's and ive only seen one other guy on here with them on his vw
    Veteran Member Four Rings PenguiN's Avatar
    Nov 12 2006
    RR Sport SC-B6S4-Gallardo
    DC
    very nice, the back needs to be a bit lower.
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta
    ^^^^^ Any lower and the rear will rub for sure.
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    I would like to know the offset as well..it looks mad aggressive!!
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Jan 06 2008
    Dacia Sandero
    Arizona
    AutoArt's are sick wheels! nice choice! Car looks good.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Very nice ride... N.E. Ohio here. I work in the "Burgh." I'm in the Steel Tower Mon, Tues & Thurs.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Quote Originally Posted by beung View Post
    the width of the tire doesn't matter.
    its the circumference of the wheels that matter. i.e. 19s up front and 20s in back. thats the stagger that you can't do. if you can stuff 275s out back and 235s in front....its fine. as long as you keep 18s all the way around or 19s etc....your fine.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Aug 11 2008
    Calgary
    Quote Originally Posted by b00st View Post
    Are you telling me that if the fronts were wider then the backs that wouldn't make a difference? It might not trip the ESP or break the AWD but it would effect how the car drives.
    In a staight line it probably does not matter but in the turn the change in width does matter and the turning radius does chance with different tire widths. Also with the staggered setup you can't put the same sized tires on both the front and the rear since the rim widths are different so you are limited in tire sizes if you want to keep the outside diameters the same for both the fronts and backs.
    The suspension is setup to have a certain amount of turn-in and drive out of the corners. You just might get too much oversteer with a staggered setup - might even trip the ESP if it's bad enough.
    Mar 05 2008
    Pittsburgh
    the reason it is soo high in the back is because it isnt lowered at all... still stock... im running a 17mm spacer in the back bc the spokes were hitting the calipers in the rear. im in a slow process of putting the 10mm spacers on n then lowering it back down
    Veteran Member Three Rings PburghNogaro's Avatar
    Dec 04 2006
    04 Nogaro S4, 71 Pontiac Grandville
    Pittsburgh, Pa
    nice S. like the wheels.
    be sure to check out the Pittsburgh People thread in the NE forum. We usually have g2gs around the city usually for a drink or two.
    where are you at in the area?
    http://www.youtube.com/watch?v=1ebxoOBIi-k
    2004 Nogaro S4 6MT - Sold
    APR res full exhaust - APR ECU - APR Snub mount - K&N - 19 BBS CKs
    1971 Pontiac Grandville
    2012 Jetta TDI
    Nov 12 2006
    DC
    wheels look really nice but I dont like the Raked look
    Veteran Member Three Rings i_eat_staples's Avatar
    Aug 03 2004
    Wilsonville, OR
    this runs contrary to everything i've ever read on these boards
    '07 rs4
    '91 spec miata
    NW Quattro - NW Premier Audi Club
