Results 1 to 8 of 8
    Awaiting Confirmation Four Rings AElucky83's Avatar
    Jul 09 2005
    00 A4TQM,91 240 SR,95 240 KADD
    Bowling Green,KY
    ABS and BRAKE lights flash and beep while driving
    Once in a while my ABS and BRAKE lamps on the gauge cluster will flash twice or so each and the beeping noise indicating a warning will sound a few times as well and then it goes away..this started just a few days ago...anyone else have or had this issue? Or know why it is doing that?
    Aug 07 2008
    ID
    Re: ABS and BRAKE lights flash and beep while driving
    is all of your brake pads good? also please check the brake fluid.
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    Brake light switch
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Established Member Two Rings 2000 A6 2.7t 6m's Avatar
    Jul 27 2007
    PA
    For me this was the ABS control module. Started intermittent and eventually the lights were always on. When the lights were on the ABS would not work. Here is a write-up that also includes some diagnosis info:
    http://www.audiworld.com/tech/elec116.shtml
    Click for Photo Album
    Upgrades:
    APR 93 ECU -=- H&R Coilovers -=- H-Sport Swaybars -=- VMR B7 RS4 Reps in Onyx Black -=- Upgraded Sound System
    Aug 21 2008
    State College, PA
    might also be the Mineral Hydro Fluid is low?
    Senior Member Three Rings PMR2.7t's Avatar
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    Had the same problem i had to replace the brake switch..
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Hmmm never heard of this before
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Oct 29 2008
    '01 S4, '90 90q20V, '98 A4q
    Virginia
    Quote Originally Posted by 2000 A6 2.7t 6m View Post
    Yes, this is absolutely the problem. All A6s will succumb to this eventually. I can repair your module for $110 if you don' feel like shelling out $500 for a used one or $1000 for a new one. Email me: [email protected]
