Results 1 to 21 of 21
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 25 2008
    Marysville, WA
    Windshield Replacement
    It seems my windshield spontaneously cracked while I was at work yesterday. It was fine when I parked in the morning, when I came out in the evening there was a pretty big crack. But there's no shatter/impact location, so it seems it just failed on its own.
    Any ideas whether this would be covered under warranty (since it's not due to a flying rock or being attacked with a baseball bat, etc.), and if not how much I might expect to pay to replace it?
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Re: Windshield Replacement
    just call and ask. windshields are only like 100-300
    Senior Member Three Rings ny2flb7a4's Avatar
    Nov 02 2006
    FL
    Call your insurance company. I had a rock chip last week and my insurance is replacing it with a new OEM windshield with $0 deductable. Good Luck.
    B7 A4 TQM Ibis Titanium pckg
    B9 SQ5 Ibis/Prestige/BO
    24 VW Golf R Lapiz 6spd
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    audi said like $500 with labor..
    Senior Member Two Rings jayM's Avatar
    Jun 28 2007
    make sure u get OEM glass, other windshield glass might not have the same greenish tint in it. (I'm sure it would bug some of us).
    2012 Mercedes-Benz C350 4matic Sedan
    2006 Audi A4 2.0t quattro - Sold
    Vancouver, Canada
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    these days... glass companies get the same windows from the same companies, but because they chop off that it's OEM or Audi part, they get to sell it at a lower cost.
    I forgot to add that you might as well get OEM which might only cost your 20-50 bucks more.
    Veteran Member Four Rings Obvis07's Avatar
    Sep 26 2007
    2007 Audi A4
    Irvine, California
    might as well get the best so u dont have to fuss with it not being able to hold up later on.
    Enjoy Life...
    Audi A4 2.0T FWD
    Current Mods:S4 DTM Edition Front Bumper, Black Grill, Black Filler Panel, Custom V2 LED (fly300kts), Iforged RS Equips, Falken FK452, H&R Spacers 5mm & 8mm, Stasis SS, Tint (35%, 5%), LED Interior, Ecode Testpipe, Magnaflow Exhaust
    No more MODs
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    Quote Originally Posted by Sanjman View Post
    When i had my b6, I bought a non-OEM windshield and the entire bottom of the windshield had a 3 inch section that was really distorted.
    I would go OEM just to be safe.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    like sdjeff said, I had a B5 that had to have a windsheild replaced and the glass they tried to put in didn't fit right. they tried again with a different piece and same issue. they then had to order a OEM piece for it! just go OEM and save your self the headache. Oh and I don't know but if you have rainsensors you might want to let the glass company know so that doesn't get messed up!
    The usual things!!
    Resistor Install
    Jul 25 2008
    Marysville, WA
    Well, I'm gonna take it in to the dealership in a couple days, they said they'll take a look and see if it's under warranty.
    If not, I'll probably try to get the OEM windshield from a third party.
    Nov 16 2006
    Skokie, IL
    either way... don't get it fixed at the dealership... they rip off... depending on the OEM glass... install should cost no more than 200 bucks.
    Senior Member Two Rings Raymax_2.0t's Avatar
    Jan 01 2008
    Tulsa, Ok.
    If you do go 3rd party, GET OEM GLASS! If something happens that could be covered under warranty and the glass isn't OEM, then the dealer won't cover it.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Once you get it looked at let me know because I have numerous small chips and it needs replaced and I'd like to see what happens with yours
    Mar 06 2008
    Midwest
    Quote Originally Posted by Raymax_2.0t View Post
    What could happen with the glass that the dealer would not cover, other than the thing breaking again? A new break would not ever be covered under warranty. Why worry about warranty in a glass situation?
    The dealer can not void out your warranty for an aftermarket part unless they can prove that the part was what caused the defect. If you put in aftermarket glass and your radio breaks they can't come back and say "sorry, you put in non oe parts, your warranty is gone." There is legislation to prevent us from such b.s. Google the Magnuson-Moss Warranty Act.
    Also, the vast majority of glass repair shops can get the O.E. glass, same as what is stock at a cheaper price as an "aftermarket" part. The only difference is that it does not have the four rings. I just got mine done this morning. Both my O.E. glass and replacement glass are made by Saint Gobain.
    Jul 25 2008
    Marysville, WA
    Well, it turned out there was about a 1mm rock chip that started it, so no warranty coverage and a quote of $525 to replace.
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    doesn't your insurance cover this? Here in MA, $0 deductible windshield coverage is standard
    Jul 25 2008
    Marysville, WA
    I have GEICO. They say they'll waive the deductible to repair, but not to replace. Unfortunately, this is a large crack right in front of the driver.
    Feb 16 2008
    Oakdale, MN
    there isn't much you can do with a cracked sheild! a rock chip they can fill. but a crack you will need a new sheild! thats weird they will repair it but not replace it!
    The usual things!!
    Resistor Install
    Registered Member Two Rings A4 S-Line's Avatar
    Dec 26 2005
    North America
    Getting mine replaced today!
    Have a $250 deductible though. Unfortunately not all US states require insurance companies to waive that for windshield replacement.
    ~Karl
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    insurance should cover it, after the deductible of course. if the chip is small, they can touch it up with some uv process for about 50 bucks.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Registered Member Two Rings 4ringdynasty's Avatar
    Nov 05 2007
    2006 Audi A4 2.0T S-Line
    Orange County
    It's been said...but
    OEM Glass
    I dealt with this when I got my car...if you have the rain sensing wipers, they dont work without it. Make sure that when it is replace the little eye behind your rear view is also adjusted properly to work with that function. It affects your auto headlights as well
    B7 A4 2.0T S-Line
